Allow / Deny ranges of address on an interface
kevin.mcguire
I have temporary network configured in a remote location.
The local facility was supposed to provide us with single, public static IP address from their ISP.  It was to have been configured so there was no traffic from any of their adjoining networks using other public static IP addresses the facility uses.
As it turns out, the facility has a dhcp server which they've programmed to have ALL the public static IP addresses via DHCP.  The static public IP address has been (supposedly) excluded from the DHCP pool.
They are not sure how to segment our connection so their is only traffic on the WAN port in and out from the ISP gateway address.  Looks like I will have to do this work on my router - traffic from devices on the same subnet are causing problems with my network/clients.
The public static IP address we've been assigned is somewhere in the middle of the range of the addresses. Gateway is the first address in the range of public static IP addresses.
When setting up the ACL for this configuration, what is the best method to achieve this?
Do I create 2 permit commands (assigned address, gateway address), Followed by a deny command for the network/subnet mask?
For example:  public static ip address is 192.168.1.23, gateway is 192.168.1.1 and subnet mask is 255.255.255.0
Are the 3 following access-list commands what I need to achieve my goal?
permit 192.168.1.23 0.0.0.255
permit 192.168.1.1 0.0.0.255
deny 192.168.1.0 0.0.0.255
Thanks!
Jon Marshall
Not sure I follow the layout.
Are your clients using private IPs and the public IP is used for NAT ?
If so why do you need an acl and how are the other public IPs causing problems with your clients.
Jon
Ah...let me make this clearer.  Here's my usual configuration:
ISP Service - with Single Static IP address for our use
      incoming service at point of entry in facility to:
ISP provided non-routing cable modem/bridge
      ethernet connection to:
Our Cisco 2951 router
1 Port is configured as the WAN port with information from the ISP to provide internet access
1 (or 2 remaining ports) are configured as the LAN port(s) with NAT'd addresses.
DHCP is activated on LAN port to hand out the IP addresses.
LAN port is configured for a single, class c subnet like 192.168.x.x.  The first 40 addresses are excluded, to be available for static assignment on the LAN and the remaining addresses are available for DHCP assignment.
In this scenario though, the facility didn't bring a separate line to go directly to our router.  This is the path in this scenario.  Equipment and connections not wanted are in italic
ISP Service providing service with 40 public IP addresses.
      incoming service to the facility's Point of Entry
ISP non routing modem/bridge
      Ethernet connection to:
Facility Router.  Configured to allow internet access - I have no information on the configuration.  Also configured as DHCP server to provide 30 of the 40 public via DHCP.  10 IP addresses were excluded from the range for me to use as public static IP addresses on our router
Facility Catalyst Switch (all ports configured to deliver addresses to clients configured for DHCP)
In this scenario, we're experiencing several strange issues:
Client devices won't pull an address via DHCP
Some clients which did pick up valid IP addresses were unable to connect to the internet, unable to ping my router's WAN address, the ISP gateway, the ISP DNS servers.
For clients that did have full internet connectivity, there was a wild variance on the speed they would get for internet access.  Sometimes up to 450 (the full speed of the ISP) down to as low as 3mbps.
In the case of the 3mbps, we discovered that a local network engineer had connected an older Cisco AP unit to the same network in the building next door.  The AP picked up one of the public addresses from the Facility's service which had the ISP Public addresses configured as available to DHCP.  After this unit was connected to the network, is when clients connected to my 2951 router started show internet speed tests of 3mbps.
Finally, I disconnected my router entirely from the Facility Catalyst switch.  I connected my PC directly to the Catalyst switch.  The PC picked up one of the available public IP addresses via DHCP and had internet access.  However, speed tests showed only 3mbps download speed.
Requested the facility network engineer to segment the network to block our traffic from the rest of the network, giving us a clean pipe directly to the internet.  For some reason they're unable to do this.
So...that puts the situation where it is now - attempting to configure the WAN port on my router to communicate only with the Gateway address and block traffic from the rest of the public addresses being used by the Facility.
As you can tell from my description, this is somewhere I haven't had to go before in our configurations.  In addition to the above, the 10 public IP addresses given for my use from the facility sit in the very middle of the full range of the public IP addresses, not at the beginning or the end of the range.
Many thanks for the detailed description
Do you have a separate internal switch for your clients ?
I still struggling to see how this would affect you assuming the ISP has setup the routing for the public IPs correctly.
And your clients not being able to get DHCP IPs from your router should have nothing to do with the WAN side of your router.
That said to try and answer your original question you should not have to allow IP to or from the ISP gateway address as this is never the source or destination IP of traffic to or from your network.
To be honest unless I have misunderstood some of your description I am struggling to see how an acl will help at all.
Jon
