Object tracking with Def Route
aamercado
Level 4
Level 4
Track and sla is up but default route override is not working. Per below, I have a static btwn the 172 host across WAN and tracking it. I am using Lo172 on both side so when I do a shut on HQ Lo172 side, the track should go down and the default route for 192 net should override the current def route for 10 but does not . If I try changing the admin dist for 192 from 10 to 8, it just installs the 0/0 for 192 net into the routing table so is a manual override for the 0/0 for 10 net. I do not want a manual override but an dynamic auto override. When I do a sh ip route track...it appears to verify that tracking it on
Remote (172.16.1.2/32)--------------WAN/track-----------------HQ (172.16.1.1/32)
ip route 0.0.0.0 0.0.0.0 192.168.1.1 10 name TO-DSL-ROUTER track 10
ip route 0.0.0.0 0.0.0.0 10.10.1.1 9 name TO-S-CORE1-UK
R-MaryAxe#SH TRACK
Load for five secs: 2%/0%; one minute: 3%; five minutes: 3%
Time source is NTP, 00:44:41.819 GMT Sat Mar 6 2010
Track 10
  IP SLA 10 reachability
  Reachability is Up
    3 changes, last change 00:13:09
  Delay up 20 secs, down 60 secs
  Latest operation return code: OK
  Latest RTT (millisecs) 36
  Tracked by:
    STATIC-IP-ROUTING 0
R-MaryAxe#sh ip route track-table
Time source is NTP, 00:52:01.832 GMT Sat Mar 6 2010
ip route 0.0.0.0 0.0.0.0 192.168.1.1 10 name TO-DSL-ROUTER track 10 state is [up]
nevermind  - it fix...i put the track on the wrong def route, should be on
ip route 0.0.0.0 0.0.0.0 10.10.1.1 9 name TO-S-CORE1-UK track 10
Giuseppe Larosa
Hello Aamercado,
yes the track has to be on the primary route
I would also make the secondary route floating by using the AD parameter like
ip route 0.0.0.0 0.0.0.0 192.168.1.1 10 name TO-DSL-ROUTER 200
Hope to help
Giuseppe
