Router Reboot
shehzadtesleem
Guys;
I have 3845 Router which is contnously rebooting; console output is attached;
any idea which part has been failed?
8 Replies 8
shehzadtesleem
No warm reboot Storage
*** System received a Cache Parity Exception ***
signal= 0x14, code= 0x14000400, context= 0x6433e04c
  PC = 0xa0000100, SP = 0x64a85918, RA = 0x600ff1f8
  Cause Reg = 0x00004000, Status Reg = 0x3400c107
System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
Copyright (c) 2005 by cisco Systems, Inc.
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
Total memory size = 256 MB - DIMM0 = 256 MB, DIMM1 = 0 MB
c3845 platform with 262144 Kbytes of main memory
Main memory is configured to 72/0(dimm 0/1) bit mode with ECC enabled
Upgrade ROMMON initialized
program load complete, entry point: 0x80010000, size: 0x209403c
Self decompressing the image : ####################################################################################################################################################################################### [OK]
Smart Init is disabled. IOMEM set to: 20
Using iomem percentage: 20
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, 3800 Software (C3845-ADVSECURITYK9-M), Version 12.4(15)T7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 14-Aug-08 00:14 by prod_rel_team
Image text-base: 0x60010930, data-base: 0x6243E2A0
Cache error detected!
  CPO_ECC     (reg 26/0): 0x40000000
  CPO_CACHERI (reg 27/0): 0x14000400
  CPO_CACHERD (reg 27/1): 0x84000060
  CPO_CCHEDPA (reg 27/3): 0x10A20000
Real cache error detected.  System will be halted.
0 spurious cache errors were previously detected.
Error: primary instr cache, fields:  tag, SysAD
virtual addr 0xA0000100, physical addr(21:3) 0x000400, vAddr(14:12) 0x0000
virtual address corresponds to main, cache word 0
Cache Data not Available for CPU 401
Address: 0xA0000100 not in TLB
: Interrupt exception, CPU signal 20, PC = 0xA0000100
   Possible software fault. Upon reccurence,  please collect
   crashinfo, "show tech" and contact Cisco Technical Support.
-Traceback= 0x6242EF44 0x600FF1F8 0x6010062C 0x6010C0CC 0x6010D250 0x603DCF78 0x60110308 0x60300000
$0 : 00000000, AT : 63F20000, v0 : 00000000, v1 : 2CDE0080
a0 : 2CDDC280, a1 : 00000000, a2 : 0001000C, a3 : 00000000
t0 : 00003073, t1 : 00000000, t2 : 63530000, t3 : 64340000
t4 : 00010010, t5 : 0000000C, t6 : 00000002, t7 : 00000001
s0 : 2CDDC280, s1 : 2CDDC250, s2 : 6425FC50, s3 : 0001000C
s4 : 00000080, s5 : 00000000, s6 : BEEFBACC, s7 : 00000000
t8 : BEEF0000, t9 : 00000000, k0 : 30408001, k1 : B0020000
gp : 63F275E0, sp : 64A62088, s8 : 64A620B0, ra : 600FF1F8
EPC  : 6242EF44, ErrorEPC : A0000100, SREG     : 3400C107
MDLO : 00310000, MDHI     : 00000000, BadVaddr : 00000000
DATA_START : 0x6243E2A0
Cause 00004000 (Code 0x0): Interrupt exception
=== Flushing messages () ===
Queued messages:
L2 ECC Counter            = 0000000000000000
Memory and IO Err Counter = 0000000000000100
Bus Watcher Counters
cor_l2cache_data_ecc_count = 0
bad_l2cache_data_ecc_count = 0
cor_l2cache_tag_ecc_count  = 0
bad_l2cache_tag_ecc_count  = 0
cor_memory_data_ecc_count  = 0
bad_memory_data_ecc_count  = 1
bus_errors                 = 0
   Possible hardware fault. This could be an one time occurence, upon reoccurence please collect
Bus Error Status Reg      = 0000000081DC0100
    Transfer ID           = CPU0 Read: read queue entry 1
    Responder ID          = MC
    Error Code            = Uncorrectable ECC Error in Data
    Multiple Errors       = No
ZBbus bits 255:192        = 0000000000000055
ZBbus bits 191:128        = 0000000000000055
ZBbus bits 127:64         = 0000000000000005
ZBbus bits  63:0          = 0000000000000005
System Revision           = 00000001112423FF
Trace buffer contents:
      24 Blockers: scd
D-bus: mc     -> cpu0  :07 dcode: DVal dirty? no
Data _00000000_00000000_00000000_00000000_00000000_00000000_00000000_00000000_
      28 Blockers: scd
D-bus: mc     -> cpu0  :00 dcode: DVal dirty? no
      29 Blockers: (none)
A-bus:WRITE      cpu0  :25 0x000CDCDE00 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
      32 Blockers: scd
D-bus: WriteData cpu0  :25 dcode: DVal dirty? yes
      36 Blockers: scd
A-bus:WRITE      cpu0  :26 0x000CDCDE20 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
      39 Blockers: (none)
D-bus: WriteData cpu0  :26 dcode: DVal dirty? yes
      40 Blockers: scd
A-bus:READ_EXC   cpu0  :07 0x000CDDFE40 be: FFFFFFFF CC/C l2miss shd:0 exc:0
      45 Blockers: (none)
A-bus:WRITE      l2    :00 0x000CD7FE40 be: FFFFFFFF CC/U l2miss shd:0 exc:0
      47 Blockers: (none)
A-bus:READ_EXC   cpu0  :00 0x000CDDFE60 be: FFFFFFFF CC/C l2miss shd:0 exc:0
      48 Blockers: scd
D-bus: WriteData l2    :00 dcode: DVal dirty? no
      52 Blockers: scd
A-bus:WRITE      l2    :00 0x000CDBFE60 be: FFFFFFFF CC/U l2miss shd:0 exc:0
      55 Blockers: (none)
      76 Blockers: scd
      81 Blockers: (none)
A-bus:WRITE      cpu0  :27 0x000CDCFE40 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
      84 Blockers: scd
D-bus: WriteData cpu0  :27 dcode: DVal dirty? yes
      85 Blockers: (none)
      90 Blockers: scd
A-bus:WRITE      cpu0  :20 0x000CDCFE60 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
      93 Blockers: (none)
D-bus: WriteData cpu0  :20 dcode: DVal dirty? yes
      94 Blockers: scd
A-bus:READ_EXC   cpu0  :07 0x000CDDFE80 be: FFFFFFFF CC/C l2miss shd:0 exc:0
      98 Blockers: scd
A-bus:READ_EXC   cpu0  :00 0x000CDDFEA0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
      99 Blockers: (none)
A-bus:WRITE      l2    :00 0x000CD8FE80 be: FFFFFFFF CC/U l2miss shd:0 exc:0
     102 Blockers: scd
     103 Blockers: (none)
A-bus:WRITE      l2    :01 0x000CDBFEA0 be: FFFFFFFF CC/U l2miss shd:0 exc:0
     106 Blockers: scd
D-bus: WriteData l2    :01 dcode: DVal dirty? no
     130 Blockers: scd
     134 Blockers: scd
     135 Blockers: (none)
A-bus:WRITE      cpu0  :21 0x000CDD1E80 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
     138 Blockers: scd
D-bus: WriteData cpu0  :21 dcode: DVal dirty? yes
     142 Blockers: scd
A-bus:WRITE      cpu0  :22 0x000CDD1EA0 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
     145 Blockers: (none)
D-bus: WriteData cpu0  :22 dcode: DVal dirty? yes
     146 Blockers: scd
A-bus:READ_EXC   cpu0  :07 0x000CDDFEC0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
     151 Blockers: (none)
A-bus:WRITE      l2    :00 0x000CDAFEC0 be: FFFFFFFF CC/U l2miss shd:0 exc:0
     153 Blockers: (none)
A-bus:READ_EXC   cpu0  :00 0x000CDDFEE0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
     154 Blockers: scd
     158 Blockers: scd
A-bus:WRITE      l2    :00 0x000CDBFEE0 be: FFFFFFFF CC/U l2miss shd:0 exc:0
     161 Blockers: (none)
     182 Blockers: scd
     187 Blockers: (none)
A-bus:WRITE      cpu0  :23 0x000CDCFEC0 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
     190 Blockers: scd
D-bus: WriteData cpu0  :23 dcode: DVal dirty? yes
     191 Blockers: (none)
     196 Blockers: scd
A-bus:WRITE      cpu0  :24 0x000CDCFEE0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
     199 Blockers: (none)
D-bus: WriteData cpu0  :24 dcode: DVal dirty? yes
     200 Blockers: scd
A-bus:READ_EXC   cpu0  :07 0x000CDDFF00 be: FFFFFFFF CC/C l2miss shd:0 exc:0
     201 Blockers: (none)
A-bus:WRITE      l2    :00 0x000CDAFEE0 be: FFFFFFFF CC/U l2miss shd:0 exc:0
     204 Blockers: scd
A-bus:READ_EXC   cpu0  :00 0x000CDDFF20 be: FFFFFFFF CC/C l2miss shd:0 exc:0
     205 Blockers: (none)
A-bus:WRITE      l2    :01 0x000CDBFF00 be: FFFFFFFF CC/U l2miss shd:0 exc:0
     208 Blockers: scd
     209 Blockers: (none)
A-bus:WRITE      l2    :00 0x000CDAFF20 be: FFFFFFFF CC/U l2miss shd:0 exc:0
     212 Blockers: scd
     236 Blockers: scd
     240 Blockers: scd
     241 Blockers: (none)
A-bus:WRITE      cpu0  :25 0x000CDCFF00 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
     244 Blockers: scd
     248 Blockers: scd
A-bus:WRITE      cpu0  :26 0x000CDD1F20 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
     251 Blockers: (none)
     252 Blockers: scd
A-bus:READ_EXC   cpu0  :07 0x000CDDFF40 be: FFFFFFFF CC/C l2miss shd:0 exc:0
     257 Blockers: (none)
A-bus:WRITE      l2    :00 0x000CD4FF40 be: FFFFFFFF CC/U l2miss shd:0 exc:0
     259 Blockers: (none)
A-bus:READ_EXC   cpu0  :00 0x000CDDFF60 be: FFFFFFFF CC/C l2miss shd:0 exc:0
     260 Blockers: scd
     264 Blockers: scd
A-bus:WRITE      l2    :00 0x000CDCFF60 be: FFFFFFFF CC/U l2miss shd:0 exc:0
     267 Blockers: (none)
     288 Blockers: scd
     293 Blockers: (none)
A-bus:WRITE      cpu0  :27 0x000CDD1F40 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
     296 Blockers: scd
     297 Blockers: (none)
     302 Blockers: scd
A-bus:WRITE      cpu0  :20 0x000CDD1F60 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
     305 Blockers: (none)
     306 Blockers: scd
A-bus:READ_EXC   cpu0  :07 0x000CDDFF80 be: FFFFFFFF CC/C l2miss shd:0 exc:0
     310 Blockers: scd
A-bus:READ_EXC   cpu0  :00 0x000CDDFFA0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
     311 Blockers: (none)
A-bus:WRITE      l2    :00 0x000CDBFF80 be: FFFFFFFF CC/U l2miss shd:0 exc:0
     314 Blockers: scd
Data _AFACEFAD_00000000_00000000_00000000_00000000_00000000_00000000_00000000_
     315 Blockers: (none)
A-bus:WRITE      l2    :01 0x000CD8FFA0 be: FFFFFFFF CC/U l2miss shd:0 exc:0
     318 Blockers: scd
     342 Blockers: scd
     346 Blockers: scd
     347 Blockers: (none)
A-bus:WRITE      cpu0  :21 0x000CDD1F80 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
     350 Blockers: scd
     354 Blockers: scd
A-bus:WRITE      cpu0  :22 0x000CDD1FA0 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
     357 Blockers: (none)
     358 Blockers: scd
A-bus:READ_EXC   cpu0  :07 0x000CDDFFC0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
     363 Blockers: (none)
A-bus:WRITE      l2    :00 0x000CDAFFC0 be: FFFFFFFF CC/U l2miss shd:0 exc:0
     365 Blockers: (none)
A-bus:READ_EXC   cpu0  :00 0x000CDDFFE0 be: FFFFFFFF CC/C l2miss shd:0 exc:0
     366 Blockers: scd
     370 Blockers: scd
A-bus:WRITE      l2    :00 0x000CDBFFE0 be: FFFFFFFF CC/U l2miss shd:0 exc:0
     373 Blockers: (none)
     394 Blockers: scd
     399 Blockers: (none)
A-bus:WRITE      cpu0  :23 0x000CDCFFC0 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
     402 Blockers: scd
     403 Blockers: (none)
     408 Blockers: scd
A-bus:WRITE      cpu0  :24 0x000CDCDFE0 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
     411 Blockers: (none)
     412 Blockers: scd
A-bus:READ_EXC   cpu0  :07 0x000CDE0000 be: FFFFFFFF CC/C l2miss shd:0 exc:0
     416 Blockers: scd
A-bus:READ_EXC   cpu0  :00 0x000CDE0020 be: FFFFFFFF CC/C l2miss shd:0 exc:0
     417 Blockers: (none)
A-bus:WRITE      l2    :00 0x000CD70000 be: FFFFFFFF CC/U l2miss shd:0 exc:0
     420 Blockers: scd
     421 Blockers: (none)
A-bus:WRITE      l2    :01 0x000CD90020 be: FFFFFFFF CC/U l2miss shd:0 exc:0
     424 Blockers: scd
     508 Blockers: scd
     512 Blockers: scd
     513 Blockers: (none)
A-bus:WRITE      cpu0  :25 0x000CDD0000 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
     516 Blockers: scd
     520 Blockers: scd
A-bus:WRITE      cpu0  :26 0x000CDD0020 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
     523 Blockers: (none)
     525 Blockers: (none)
A-bus:READ_EXC   cpu0  :00 0x000CDE0040 be: FFFFFFFF CC/C l2miss shd:0 exc:0
     530 Blockers: scd
A-bus:WRITE      l2    :00 0x000CDD0040 be: FFFFFFFF CC/U l2miss shd:0 exc:0
     531 Blockers: (none)
A-bus:READ_EXC   cpu0  :01 0x000CDE0060 be: FFFFFFFF CC/C l2miss shd:0 exc:0
     533 Blockers: (none)
     536 Blockers: scd
A-bus:WRITE      l2    :00 0x000CDD0060 be: FFFFFFFF CC/U l2miss shd:0 exc:0
     539 Blockers: (none)
     562 Blockers: scd
     567 Blockers: (none)
A-bus:WRITE      cpu0  :27 0x000CDCE040 be: FFFFFFFF CC/C l2 hit shd:0 exc:0
     570 Blockers: scd
     571 Blockers: (none)
D-bus: mc     -> cpu0  :01 dcode: Uncorrectable_ECC_data_error dirty? no
Data _00000000_00000005_00000000_00000005_00000000_00000055_00000000_00000055_
  CPU temp is 55
  Temp1 temp is 34
  Temp2 temp is 28
  Internal voltage is 3300
  Remote voltage1 is 5210
  Remote voltage2 is 2525
  Remote voltage3 is 1215
signal= 0x14, code= 0x14000400, context= 0x64339a0c
  PC = 0xa0000100, SP = 0x64a62088, RA = 0x600ff1f8
I would suggest you to open up a TAC case as soon as possible.
please rate the helpfull posts.
Naidu.
I dont have CCO login; any body can help
Unfortunately there is a hardware problem.
If you don't have a CCO login, you have to contact your reseller.
Best regards,
Giorgos
is there any probelm with Flash and ROM?
OK, here's what you can do. First of all power off the router, remove all network modules and power on.
Is the router still rebooting?
Giorgos
All Module are un-plugged but problem is the same
Well, there seems to be a problem with the memory modules. Is there any chance of checking with new ones?
Keep in mind though that it would be wise to call the reseller and avoid opening the chassis.
Giorgos
