OER and routing problems
kbozung
I'm trying to create a load-balanced/fail-over configuration for a customer using a single router. My customer can't get any routing information from the ISP and most likley will not have a down interface during an outage I thought OER would be the ideal way to go. I'm having all kinds of difficulty with this.
My test lab has a DSL connection and a Cable modem connection which both have dynamic IP addressing. I have a Cisco 2811 router with a 4-port 10/100 HWIC. The integrated FA ports are configured for the ISP connections. I've created a VLAN on 4-port HWIC to communicate with my LAN. At this time I'm not convinced I have an OER problem but more of a general routing issue. My first question is how should I create my default routes? If I create two 'ip route 0.0.0.0 0.0.0.0 fa0/x DHCP' nothing works, I'll intermittenly get a packet to go through. I thought this was a pretty normal configuration? I currently have the two default routes configured with different administrative distances. This allows me to get to the Internet but fail-over doesn't happen during a brown-out, OER doesn't take over. Attached is my configuration, I've tried this with all OER configuration removed still no luck.
My second question is, does anybody have a functional OER configuration they could share? Information on this is hard to come by. Any suggestions would be appreciated.
version 12.4
hostname Cisco2811
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no logging console
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip domain lookup
ip domain name yourdomain.com
key chain OER
key 1
key-string abcd1234
oer master
policy-rules OER
max-range-utilization percent 50
logging
border 1.1.1.1 key-chain OER
interface Vlan100 internal
interface FastEthernet0/0 external
interface FastEthernet0/1 external
learn
throughput
periodic-interval 1
monitor-period 2
prefixes 250
mode route control
mode select-exit best
oer border
local Loopback0
master 1.1.1.1 key-chain OER
username cisco privilege 15 secret xxx
interface Loopback0
ip address 1.1.1.1 255.255.255.255
description Ethernet to WAN ISP1
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
description Ethernet to WAN ISP2
ip address dhcp
ip nat outside
duplex auto
speed auto
interface FastEthernet0/0/0
switchport access vlan 100
vlan-id dot1q 100
exit-vlan-config
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Vlan1
no ip address
interface Vlan100
description LAN VLAN
ip address 192.168.10.1 255.255.255.0
ip nat inside
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 dhcp 11
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 dhcp 10
ip nat inside source route-map CHARTER interface FastEthernet0/0 overload
ip nat inside source route-map UTMI-DSL interface FastEthernet0/1 overload
ip prefix-list OER seq 10 permit 0.0.0.0/0
access-list 100 permit ip 192.168.0.0 0.0.255.255 any
route-map CHARTER permit 10
match ip address 100
match interface FastEthernet0/0
route-map UTMI-DSL permit 10
match interface FastEthernet0/1
oer-map OER 10
match ip address prefix-list OER
control-plane
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
8 Replies 8
Adam Frederick
Level 3
Level 3
Try this;
no ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 dhcp 11
no ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 dhcp 10
I've only implemented OER once, but from what I recall you want equal cost paths, however I do believe it works w/ unequal cost paths but just for testing sakes try this out and see if there is any difference. If the IP from the provider never changes even though it is DHCP, you could try pointing to that IP address in the static route, even just for testing it would be worth a shot. Depending on what type of connection you have from each provider, you may be better off using basic CEF load balancing..
paolo bevilacqua
Perhaps OER is too much an overkill for this application ?
Your could try PBR for multiple tracking
http://cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080457bcc.html
It is much simpler and would support a dual connection/NAT/backup scenario.
I was thinking about all this and there may be implications depending on the order in which the inside interface processes PBR and NAT, thing that I'm not sure about.
So I would need to lab this out before saying for sure.
I hope to be able to do that after I'm back from a trip I'm taking now.
Okay. I've decided to simplify this. I removed all the OER configuration. All I have now are two Internet connections both set as default routes. Both interfaces are set to do NAT overloading. As before Internet access is extremely spotty and slow. I'm thinking about wiping my configuration and starting over but there just isn't that much in here. Please see current config. Thank you for your replies.
version 12.4
hostname 2811
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip domain lookup
username cisco privilege 15 secret 5 $1$
ip address dhcp
ip nat outside
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
vlan-id dot1q 100
exit-vlan-config
interface Vlan1
no ip address
interface Vlan100
ip nat inside
ip classless
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
end
Osprey2811#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
68.0.0.0/32 is subnetted, 1 subnets
S 68.114.36.54 [254/0] via 66.227.208.1, FastEthernet0/0
C 192.168.10.0/24 is directly connected, Vlan100
66.0.0.0/22 is subnetted, 1 subnets
C 66.227.208.0 is directly connected, FastEthernet0/0
67.0.0.0/24 is subnetted, 1 subnets
C 67.59.46.0 is directly connected, FastEthernet0/1
S* 0.0.0.0/0 is directly connected, FastEthernet0/0
Osprey2811#
One more thing. I removed all my NAT configuration and performed ping tests from the router. The behavior is the same without NAT. The only way I can get reliable outbound access is to set unequal cost default routes or disabling one of the interfaces. Thanks.
Well I opened up a case with Cisco. The engineer had me remove all default routes. Because the interfaces were on DHCP they automatically learn a default route. These default routes end up in the routing table. Just like that everything started working properly.
I'm still working on some OER related problems. Once I have it all done I'll post a final config.
Success!!! For anybody following in my foot steps be aware of your testing procedures. My method of testing was to send several continuous pings from my PC to different locations on the Internet. This lead me to believe I had a problem because some of the connections would drop and not come backup. The reason they wouldn't come back up was not because OER wasn't working but because my continuous ping never allowed my dynamic NAT translation to clear out. The default timeout for a NAT translation is 60 seconds.
Thank you to everybody who helped on this.
version 12.4
hostname Cisco2811
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
ip cef
no ip domain lookup
key chain OER
key 1
key-string OER-KEY-123
crypto pki trustpoint TP-self-signed-xxx
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3209123731
revocation-check none
rsakeypair TP-self-signed-xxx
crypto pki certificate chain TP-self-signed-3209123731
certificate self-signed 01 nvram:IOS-Self-Sig#3131.cer
oer master
policy-rules OER
logging
learn
throughput
periodic-interval 1
monitor-period 2
prefixes 250
mode route control
mode monitor active
active-probe echo 66.227.208.1
active-probe echo 67.59.46.1
oer border
local Loopback0
interface Loopback0
ip address 1.1.x.x.255.255.255
bandwidth 3072
ip address dhcp
ip nat outside
duplex auto
speed auto
bandwidth 384
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan100
ip nat inside
ip http server
ip nat translation icmp-timeout 15
ip nat inside source route-map CHARTER interface FastEthernet0/0 overload oer
ip nat inside source route-map UTMI-DSL interface FastEthernet0/1 overload oer
ip prefix-list OER seq 5 permit 0.0.0.0/0
oer-map OER 10
control-plane
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
line vty 5 15
access-class 23 in
privilege level 15
login local
end
What is the function of IP prefix list?
