Older non Cyrpto version. How to poke a hole in my ACL so my ISP can monitor my router?
badassmexican
I'm trying to figure out how to block ports and secure my older router that doesn't have SSL, crypto, ip inspect and I'm sure I'm missing a few other things.
I added these to my my config file but I think it might have worked too well because my ISP sent me an email asking that I open it up for their monitoring IPs.
Am I doing this right or is there a better way to do this?  Also, how can I allow ICMP requests from my ISP?
Joel
interface FastEthernet0/1
description Uplink
ip address 38.88.245.170 255.255.255.248
ip nat outside
ip access-group cbac in
ip access-list extended cbac
permit icmp any any echo-reply
permit tcp any any eq bgp
permit udp any any eq bootpc
permit udp any any eq snmp
permit tcp any any established
deny   ip any any
This is what my ISP sent me:
Cogent is unable to proactively test the status of your circuit
(IP Address 38.88.245.170) because it appears that there is a
universal ICMP block in place.
This can be resolved by blocking all ICMP traffic except from
the Cogent monitoring IP blocks of
66.28.3.0/24,
66.250.250.0/23,
130.117.228.0/24  and
130.117.254.0/24 for IPv4
luis_cordova
Hi @badassmexican,
Try adding this to your ACL:
deny   ip any any
Hello
Not so sure why would you want to allow an ISP to monitor your rtr - it can do that on a physical level without you allowing them any access?
A ISP is there to provide you a service not for you to provide them one.
Kind Regards
Paul
Yeah, I'm not really sure either.  They don't really offer any support.  If it's working I'm sure I'll know before they do.  This is what they said though:
Unfortunately if Cogent is unable to monitor the IP specified it is impossible for us to honor the Guarantees and Service Credits provided in any Service Level Agreement, Customer Service Agreement or other type of performance level agreement that you currently have with Cogent Communications. More importantly, it makes it impossible for Cogent Support to proactively troubleshoot problems because we have no visibility.
