One BGP neighbor won't advertise its TokenRing subnet
CriscoSystems
Level 5
Level 5
RouterJ and RouterH are connected on a b2b PPP link, 215.0.0.18/30 (J) and .17(30)H. H is connected to an up-and-running TokenRing segement, 10.4.4.0/24. H's BGP config looks like this:
router bgp 50
bgp log-neighbor-changes
network 10.4.4.0
neighbor 215.0.0.18 remote-as 100
but its table contains only the 4 loopbacks being advertised to it by J
RouterH#sh ip bgp
BGP table version is 49, local router ID is 215.0.0.17
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 205.1.12.0 215.0.0.18 0 0 100 i
*> 205.1.13.0 215.0.0.18 0 0 100 i
*> 205.1.14.0 215.0.0.18 0 0 100 i
*> 205.1.15.0 215.0.0.18 0 0 100 i
RouterH#
going over to Router J, we have a BGP config of:
router bgp 100
network 205.1.12.0
network 205.1.13.0
network 205.1.14.0
network 205.1.15.0
neighbor 215.0.0.17 remote-as 50
and a bgp table of:
RouterJ#sh ip bgp
BGP table version is 5, local router ID is 205.1.15.1
*> 205.1.12.0 0.0.0.0 0 32768 i
*> 205.1.13.0 0.0.0.0 0 32768 i
*> 205.1.14.0 0.0.0.0 0 32768 i
*> 205.1.15.0 0.0.0.0 0 32768 i
RouterJ#
The 10.4.4.0/24 network was declared on H's BGP process and the segment is up and running, so why is it not being advertised over to J?
mibrahim81
Dear sir,
Could you told me if summarization enabled or not under BGP process on router H.
Edison Ortiz
Make sure to have auto-summary disabled under BGP and also have this command instead,
network 10.4.4.0 mask 255.255.255.0
HTH,
__
Edison.
