one lan in different location
eng_adel273
I have two locations (Location A & Location B). I have data MPLS lease-line to connect this two location with two Cyberoam . I want to configure Same subnet IP address on LAN of both locations.
so I need to specify same subnet IP on both sides.Please suggest me and help me to do so.
I want to communicate Location-B  IP 192.168.47.1 to Location-A IP 192.168.47.1.5.
attached diagram
ahmedshoaib
Level 4
Level 4
Hi;
To assign the same IP address on multiple site, then you have following option:
1. Instead of IP-VPN MPLS circuit you need to use L2 MPLS Circuit.
2. In case if you have Cisco ASR or Nexus switches on both side you can configure OTV.
Thanks & Best regards;
