06-18-2016 12:42 AM - edited 03-05-2019 04:15 AM
whats is the best way
dual link single router
dual link multiple router (2)
I have 2 wan links and need to do wan failover in router.
06-18-2016 01:13 AM
That depends on what you want to achieve. If you are only interested in protection against external link failures, one router is fine. If you want redundancy also in case the router fails or is in maintenance, then two routers are the way to go. Be aware that using two routers will make your setup slightly more complex.
06-19-2016 12:20 AM
We need wan failover. We dont want redundancy in case of router failure.
06-19-2016 10:35 AM
well, that really answers your question ... One router with two links.
06-18-2016 02:28 AM
Hello
Also would you like to utilise both wan links at the same time ( load sharing) or have a primary and secondary redundancy ?
res
paul
06-19-2016 12:18 AM
we need to have a primary and secondary redundancy
