I have a case that the router receives higher number of DLCIs from the FR switch via LMI. Is it possible to configure the router in a way that it learns just those DLCIs that it actually uses.
The LMI announces the DLCIs that the provider has configured on that connection. I do not believe that there is any way to configure the router to learn only some of the DLCIs that the provider is announcing.
Rick
Rick
Learn, share, save
