Open ports 8010,8015 and 8020 on a Cisco C1111-4P.
Stephanhup
Does anyone know how i can shut these open ports down.
With NMAP i see that the ports are open from the outside
9 Replies 9
M02@rt37
Hello @Stephanhup
Do an ACL but be sure these ports are not necessary.
ip access-list extended WAN_IN
deny tcp any any eq 8010
Repeat this for ports 8015 and 8020 as needed.
Best regards
Thank you for your information, i have but the port still says open.. i have it with multiple Cisco C1111-4P. Like 200 of them..
i have forwarded the port to a unknown (not configured) ip-adress as a test, but it still says the port is up.
See the screencap
is this device doing any NAT ?
as i suggest best to deploy ACL to deny those ports to secure the router.
BB
Yes i have, on the Dialer.
interface Dialer1
ip access-group Public_ACL in
ip access-list extended Public_ACL
1 deny tcp any any eq 8010 log
2 deny tcp any any eq 8015 log
3 deny tcp any any eq 8020 log
balaji.bandi
Depends on what service are running the router and where this Router Located in the network and role ?
Best is put ACL on the outside interface, so it will be secured from Internet access to device.
BB
#show run | i service
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
Stephanhup
Thank you all for your comments. I found the problem. All tests, from multiple WAN connections, went through a Fortigate firewall. This performed package inspection, I think he has shown that the ports are open because of the inspection. We tested it with more different routers and they said the port was closed.
Hello @Stephanhup
Thanks for your feedback
Best regards
