01-19-2022
07:13 AM
- last edited on
01-22-2022
04:43 AM
by
Translator
Hey everyone.
I'm new here, and trying to learn.
I recently aquired an Cisco ISR1100 (basic license) and I got it set up for normal internet traffic.
But i'm struggling with getting ports opened for my server on the inside.
I've tried messing around with different configurations on the
ip route and acl's,
but to no avail.
I hope you can help me figure out, what i'm doing wrong.
I'm trying to get traffic through from VLAN101 (outside), to my VLAN777 (inside) where I have an HTTPS server running.
I have tried placing the ACL "SEC-OPEN" on VLAN777, VLAN101, all physical interfaces and even on my NAT - but nothing changes. It keeps on telling me that the connection was refused, when pinging my internal devices, from outside.
Thanks in advance.
My configuration is as follows:
R1-1100#show run
Building configuration...
Current configuration : 8337 bytes
! Last configuration change at 23:34:32 UTC Sun Jan 16 2022
version 16.12
service password-encryption
service call-home
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
hostname R1-1100
boot-start-marker
boot-end-marker
enable secret 9 XXXXXXXX
no aaa new-model
ip name-server 8.8.8.8 8.8.4.4
ip domain name R1-1100
ip dhcp excluded-address 192.168.0.255 255.255.255.255
ip dhcp excluded-address 192.168.0.1 192.168.0.100
ip dhcp pool LAN
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 8.8.8.8 8.8.4.4
lease 30
no ip dhcp auto-broadcast
login on-success log
subscriber templating
vtp mode transparent
diagnostic bootup level minimal
username XXXXXXXX privilege 15 secret 9 XXXXXXXX
redundancy
mode none
vlan internal allocation policy ascending
vlan 101,777
interface GigabitEthernet0/0/0
description *** NOT USED ***
ip address dhcp
ip nat outside
shutdown
media-type rj45
negotiation auto
interface GigabitEthernet0/0/1
description *** ISP ***
no ip address
media-type rj45
negotiation auto
interface GigabitEthernet0/0/1.101
description *** VLAN101 ***
encapsulation dot1Q 101
ip address dhcp
ip nat outside
interface GigabitEthernet0/1/0
description *** LAN ***
switchport access vlan 777
switchport mode access
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface GigabitEthernet0/1/4
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
interface Vlan1
description *** NATIVE ***
no ip address
interface Vlan101
no ip address
interface Vlan777
ip address pool LAN
ip nat inside
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list SEC-INTERNET interface GigabitEthernet0/0/1.101 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/1.101 dhcp
ip ssh maxstartups 2
ip ssh rsa keypair-name SSH
ip access-list extended SEC-INTERNET
10 permit ip 192.168.0.0 0.0.0.255 any
20 deny ip any any
ip access-list extended SEC-OPEN
10 permit ip any any
ip access-list extended SEC-SERVER
10 permit ip host 192.168.0.55 any
20 permit ip any host 192.168.0.55
30 deny ip any any
ip access-list extended SEC-VTY
10 permit tcp 192.168.0.0 0.0.0.255 host 192.168.0.1 eq 22
20 deny ip any any
control-plane
line con 0
privilege level 15
logging synchronous
length 0
transport input none
stopbits 1
line vty 0 4
access-class SEC-VTY in
logging synchronous
login local
length 0
transport preferred ssh
ntp server time.google.com
end
R1-1100#
Solved! Go to Solution.
01-19-2022
09:41 PM
- last edited on
01-21-2022
02:29 AM
by
Translator
To allow access from outside to your server on the inside, static nat is required. If your web server is 192.168.0.55, the the nat statement will be:
ip nat inside source static tcp 192.168.0.55 443 interface GigabitEthernet0/0/1.101 443
John
01-19-2022
09:41 PM
- last edited on
01-21-2022
02:29 AM
by
Translator
John
01-19-2022 09:56 PM
Thank you so much, John... That worked
-Morten
