Opspf default-information originate and Static routing resdistribution
Sasquatch_13
Hello all,
I am doing OSPF config.
Fortinate is connected to Core Switch, using deafult route.
On Core Switch has many static routes, I want to Redistribute Static route into OSPF and filter Static route using access list and route-map.
But in ospf default-information originate in ospf causes all route to pass Via Core Switch.
Please Help to me filter Redistributed Static Route.
******Core Switch
router ospf 10
log-adjacency-changes detail
redistribute static metric 20 metric-type 1 subnets tag 13 route-map BlockStatic
network 172.17.254.1 0.0.0.0 area 0
network 172.17.254.5 0.0.0.0 area 0
network 172.17.254.255 0.0.0.0 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.17.254.150       #### (Fortinate default route)
ip route 10.1.1.1 255.255.255.255 172.17.254.130
ip route 192.168.13.13 255.255.255.255 172.17.254.130
ip route 192.168.14.10 255.255.255.255 172.17.254.130
ip access-list standard Route
permit 10.1.1.1
deny any
route-map BlockStatic permit 10
match ip address Route
set metric 200
15 Replies 15
match ip address prefix Route
set metric 200
route-map BlockStatic permit 20
ip prefix-list Route seq 10 permit 10.1.1.1/32
use prefix instead as shown above, AND ALSO ADD SECOND ROUTE_MAP LINE
and why there is two metric ??? you want to change the metric for this prefix to be 200 and other to be 20?
Sasquatch_13
Metric is not concern for me I just and want to block some Static redistribute route into ospf domain
if you want only 10.1.1.1/32 then
same only
route-map BlockStatic permit 20<<- REMOVE THIS
Sasquatch_13
I Changed the config to this but same issue... I am sharing the route table of Distribution switch
router ospf 10
redistribute static metric-type 1 subnets tag 13 route-map BlockStatic
no ip http server
match ip address prefix-list Route
set metric 200
D1(config)#exit
D1#sh ip r
*Aug 5 20:06:00.053: %SYS-5-CONFIG_I: Configured from console by consoleoute
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override
Gateway of last resort is 172.17.254.1 to network 0.0.0.0
O*E2 0.0.0.0/0 [110/1] via 172.17.254.1, 00:08:09, GigabitEthernet0/0
10.0.0.0/32 is subnetted, 1 subnets
O E1 10.1.1.1 [110/201] via 172.17.254.1, 00:08:09, GigabitEthernet0/0
172.17.0.0/16 is variably subnetted, 13 subnets, 5 masks
C 172.17.200.0/27 is directly connected, Vlan200
L 172.17.200.1/32 is directly connected, Vlan200
C 172.17.210.0/28 is directly connected, Vlan210
L 172.17.210.1/32 is directly connected, Vlan210
C 172.17.230.0/24 is directly connected, Vlan230
L 172.17.230.1/32 is directly connected, Vlan230
C 172.17.254.0/30 is directly connected, GigabitEthernet0/0
L 172.17.254.2/32 is directly connected, GigabitEthernet0/0
O 172.17.254.4/30
[110/2] via 172.17.254.25, 00:08:09, GigabitEthernet0/1
[110/2] via 172.17.254.1, 00:08:09, GigabitEthernet0/0
C 172.17.254.24/30 is directly connected, GigabitEthernet0/1
L 172.17.254.26/32 is directly connected, GigabitEthernet0/1
C 172.17.254.253/32 is directly connected, Loopback1
O 172.17.254.255/32
ip route 0.0.0.0 0.0.0.0 172.17.254.150 <<- this advertise as E2 please see note below
ip route 10.1.1.1 255.255.255.255 172.17.254.130 <<- this advertise as E1 so route-map is OK
ip route 192.168.13.13 255.255.255.255 172.17.254.130 <<- this not advertise as E1 so route-map is OK
ip route 192.168.14.10 255.255.255.255 172.17.254.130 <<- this not advertise as E1 so route-map is OK
router ospf 10
default-information originate <<<- you advertise 0.0.0.0/0 here
the route-map with prefix work perfectly and not advertise the 50.0.0.0/24
but still R1 advertise the Default route because of default-information origin not because redistribute static.
NOTE:- the OSPF handle the default route not like static route that why default-information command is add to OSPF.
Sasquatch_13
I think that blocked static route are going through default static route which is originated by ospf (default-informattion originate)
Hello
As that router is redistributing statica it is in theroy an ASBR as such you should be able negate prefixes egress
ip prefix-list no-default deny 0.0.0.0/0
ip prefix-list tst permit 0.0.0.0/0 le 32
router ospf 10
distribute-list prefix no-default out
or apply the filter on the router you do not want to receive the default
router ospf 10
distribute-list prefix no-default in
Kind Regards
Paul
Sasquatch_13
Hi Paul,
Sasquatch_13
Hi,MHM
Why you use null0 static route ??
I am sharing my new config.
Sasquatch_13
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2022.08.06 11:29:34 =~=~=~=~=~=~=~=~=~=~=~=
sh run
% Invalid input detected at '^' marker.
D1>en
D1#sh run'
Building configuration...
Current configuration : 4280 bytes
! Last configuration change at 03:51:02 UTC Sat Aug 6 2022
version 15.2
service compress-config
hostname D1
boot-start-marker
boot-end-marker
no aaa new-model
--More--  !
ip cef
no ipv6 cef
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
--More--  !
interface Loopback1
ip address 172.17.254.253 255.255.255.255
interface GigabitEthernet0/2
switchport mode trunk
media-type rj45
negotiation auto
interface GigabitEthernet0/3
media-type rj45
negotiation auto
interface GigabitEthernet0/0
no switchport
ip address 172.17.254.2 255.255.255.252
negotiation auto
interface GigabitEthernet0/1
--More--   no switchport
ip address 172.17.254.26 255.255.255.252
negotiation auto
interface GigabitEthernet1/0
media-type rj45
negotiation auto
interface GigabitEthernet1/1
media-type rj45
negotiation auto
interface GigabitEthernet1/2
media-type rj45
negotiation auto
interface GigabitEthernet1/3
media-type rj45
negotiation auto
interface GigabitEthernet2/0
media-type rj45
negotiation auto
--More--  !
interface GigabitEthernet2/1
media-type rj45
negotiation auto
interface GigabitEthernet2/2
media-type rj45
negotiation auto
interface GigabitEthernet2/3
media-type rj45
negotiation auto
interface GigabitEthernet3/0
media-type rj45
negotiation auto
interface GigabitEthernet3/1
media-type rj45
negotiation auto
interface GigabitEthernet3/2
media-type rj45
--More--   negotiation auto
interface GigabitEthernet3/3
media-type rj45
negotiation auto
interface Vlan200
ip address 172.17.200.1 255.255.255.224
interface Vlan210
ip address 172.17.210.1 255.255.255.240
interface Vlan230
ip address 172.17.230.1 255.255.255.0
router ospf 30
passive-interface default
no passive-interface GigabitEthernet0/0
no passive-interface GigabitEthernet0/1
network 172.17.200.1 0.0.0.0 area 30
network 172.17.210.1 0.0.0.0 area 30
network 172.17.230.1 0.0.0.0 area 30
--More--   network 172.17.254.2 0.0.0.0 area 0
network 172.17.254.26 0.0.0.0 area 0
network 172.17.254.253 0.0.0.0 area 0
no ip http server
control-plane
banner exec ^C
* IOSv is strictly limited to use for evaluation, demonstration and IOS *
* education. IOSv is provided as-is and is not supported by Cisco's *
* Technical Advisory Center. Any use or disclosure, in whole or in part, *
* of the IOSv Software or Documentation to any third party for any *
* purposes is expressly prohibited except as otherwise authorized by *
--More--  * Cisco in writing. *
**************************************************************************^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
--More--  line vty 0 4
login
end
D1#sh ip route
O*E2 0.0.0.0/0 [110/1] via 172.17.254.1, 01:37:39, GigabitEthernet0/0
10.0.0.0/24 is subnetted, 1 subnets
O E1 10.10.1.0 [110/21] via 172.17.254.1, 00:02:52, GigabitEthernet0/0
20.0.0.0/24 is subnetted, 1 subnets
O E1 20.10.1.0 [110/21] via 172.17.254.1, 00:02:52, GigabitEthernet0/0
--More--  C 172.17.230.0/24 is directly connected, Vlan230
O 172.17.254.4/30
[110/2] via 172.17.254.25, 00:19:42, GigabitEthernet0/1
[110/2] via 172.17.254.1, 01:37:39, GigabitEthernet0/0
O 172.17.254.255/32
D1#ping 30.10.1.1
Sending 5, 100-byte ICMP Echos to 30.10.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 25/38/54 ms
D1#sh ip route 301=  .10.1.1
% Network not in table
D1#
network 172.17.254.2 0.0.0.0 area 0 <<- what about this prefix ? I dont get what you want here ?
Sasquatch_13
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2022.08.06 11:32:33 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Current configuration : 4482 bytes
! Last configuration change at 05:31:38 UTC Sat Aug 6 2022
version 15.2
hostname CIT
boot-start-marker
boot-end-marker
no aaa new-model
--More--  !
ip cef
no ipv6 cef
--More--  !
interface Loopback1
ip address 172.17.254.255 255.255.255.255
no switchport
ip address 172.17.254.1 255.255.255.252
negotiation auto
no switchport
ip address 172.17.254.5 255.255.255.252
negotiation auto
no switchport
ip address 172.17.254.149 255.255.255.252
negotiation auto
ip address 172.17.254.129 255.255.255.252
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
--More--  !
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
media-type rj45
negotiation auto
router ospf 10
redistribute static metric-type 1 subnets tag 13 route-map static-ospf
no ip http server
ip route 10.10.1.0 255.255.255.0 172.17.254.130
ip route 10.10.1.1 255.255.255.255 172.17.254.130
ip route 20.10.1.0 255.255.255.0 172.17.254.130
--More--  ip route 30.10.1.0 255.255.255.0 172.17.254.130
ip prefix-list External-Route seq 5 permit 10.10.1.0/24
ip prefix-list External-Route seq 10 permit 20.10.1.0/24
ip prefix-list External-Route seq 15 deny 30.10.1.0/24
route-map static-ospf permit 10
match ip address prefix-list External-Route
control-plane
banner exec ^C
--More--  **************************************************************************^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
--More--   login
end
CIT#sh ip route
Gateway of last resort is 172.17.254.150 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 172.17.254.150
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
S 10.10.1.0/24 [1/0] via 172.17.254.130
S 10.10.1.1/32 [1/0] via 172.17.254.130
S 20.10.1.0 [1/0] via 172.17.254.130
30.0.0.0/24 is subnetted, 1 subnets
S 30.10.1.0 [1/0] via 172.17.254.130
172.17.0.0/16 is variably subnetted, 14 subnets, 5 masks
O IA 172.17.200.0/27
--More--   [110/2] via 172.17.254.2, 01:44:46, GigabitEthernet0/0
O IA 172.17.210.0/28
O IA 172.17.230.0/24
L 172.17.254.1/32 is directly connected, GigabitEthernet0/0
C 172.17.254.4/30 is directly connected, GigabitEthernet0/1
L 172.17.254.5/32 is directly connected, GigabitEthernet0/1
O 172.17.254.24/30
[110/2] via 172.17.254.6, 00:23:35, GigabitEthernet0/1
C 172.17.254.128/30 is directly connected, GigabitEthernet0/3
L 172.17.254.129/32 is directly connected, GigabitEthernet0/3
C 172.17.254.148/30 is directly connected, GigabitEthernet0/2
L 172.17.254.149/32 is directly connected, GigabitEthernet0/2
O 172.17.254.253/32
C 172.17.254.255/32 is directly connected, Loopback1
CIT#  sh ip route 30.10.1.1
Routing entry for 30.10.1.0/24
Known via "static", distance 1, metric 0
Redistributing via ospf 10
Routing Descriptor Blocks:
* 172.17.254.130
Route metric is 0, traffic share count is 1
CIT#
