Opspf default-information originate and Static routing resdistribution
Sasquatch_13
Hello all,
I am doing OSPF config.
Fortinate is connected to Core Switch, using deafult route.
On Core Switch has many static routes, I want to Redistribute Static route into OSPF and filter Static route using access list and route-map.
But in ospf default-information originate in ospf causes all route to pass Via Core Switch.
Please Help to me filter Redistributed Static Route.
******Core Switch
router ospf 10
log-adjacency-changes detail
redistribute static metric 20 metric-type 1 subnets tag 13 route-map BlockStatic
network 172.17.254.1 0.0.0.0 area 0
network 172.17.254.5 0.0.0.0 area 0
network 172.17.254.255 0.0.0.0 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.17.254.150       #### (Fortinate default route)
ip route 10.1.1.1 255.255.255.255 172.17.254.130
ip route 192.168.13.13 255.255.255.255 172.17.254.130
ip route 192.168.14.10 255.255.255.255 172.17.254.130
ip access-list standard Route
permit 10.1.1.1
deny any
route-map BlockStatic permit 10
match ip address Route
set metric 200
15 Replies 15
Your config fir CIT is correct,
but you check the prefix in same router that the subnet is static learn? this not right,
you check in any other OSPF neighbor router.
