OSPF ADJ FLAPPING
Nirmalbang
Hi All,
I am facing a strange issues forming adjacency between Cisco 3850 and a fortigate. There are two redundant p2p link. On one link every thing is working fine but one a second link the adjacency is flapping.I am posting here a log which continuously i am getting on 3850. If any one here can suggest what further can i check to resolve this adjacency problem.
Oct 24 16:11:18.965: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from FULL to INIT, 1-Way
Oct 24 16:11:18.973: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from INIT to 2WAY, 2-Way Received
Oct 24 16:11:18.974: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from 2WAY to EXSTART, AdjOK?
Oct 24 16:11:18.993: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from EXSTART to EXCHANGE, Negotiation Done
Oct 24 16:11:19.020: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from EXCHANGE to LOADING, Exchange Done
Oct 24 16:11:19.020: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from LOADING to FULL, Loading Done
Oct 24 16:34:16.084: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from FULL to INIT, 1-Way
Oct 24 16:34:16.093: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from INIT to 2WAY, 2-Way Received
Oct 24 16:34:16.093: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from 2WAY to EXSTART, AdjOK?
Oct 24 16:34:16.139: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from EXSTART to EXCHANGE, Negotiation Done
Oct 24 16:34:16.170: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from EXCHANGE to LOADING, Exchange Done
Oct 24 16:34:16.170: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from LOADING to FULL, Loading Done
Oct 24 16:34:26.214: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from FULL to INIT, 1-Way
Oct 24 16:34:26.223: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from INIT to 2WAY, 2-Way Received
Oct 24 16:34:26.223: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from 2WAY to EXSTART, AdjOK?
Oct 24 16:34:26.242: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from EXSTART to EXCHANGE, Negotiation Done
Oct 24 16:34:26.270: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from EXCHANGE to LOADING, Exchange Done
Oct 24 16:34:26.270: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from LOADING to FULL, Loading Done
Oct 24 16:34:40.795: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from FULL to INIT, 1-Way
Oct 24 16:34:40.803: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from INIT to 2WAY, 2-Way Received
Oct 24 16:34:40.803: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from 2WAY to EXSTART, AdjOK?
Oct 24 16:34:40.822: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from EXSTART to EXCHANGE, Negotiation Done
Oct 24 16:34:40.849: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from EXCHANGE to LOADING, Exchange
Oct 24 16:34:40.849: %OSPF-5-ADJCHG: Process 1, Nbr 1.0.0.1 on GigabitEthernet2/0/11 from LOADING to FULL, Loading Done
Nbang_GPX_L3#terminal no mo
Nbang_GPX_L3#terminal no monitor
Nbang_GPX_L3#unde
Nbang_GPX_L3#undebug al
Nbang_GPX_L3#undebug all
All possible debugging has been turned off
Nbang_GPX_L3#
redundant meaning one is active and the other not ? Make sure hello and dead timers are exchanged (both Cisco and Fortigate default to 10 and 40 seconds respectively).
No both the links are active active and i had tried setting up the hello and dead interval at both end still the flapping is happening
is the interface where the flapping occurs configured as OSPF network type point to point ? Can you post the output of 'show ip ospf interface ?
Hi, This is really strange but i changed the interface ip of both cisco and fortigate and reconfigured ospf and now things are working fine, really a strange behavior. Thanks for your help
