OSPF Adjacency Error Please Help
moles3144
Community Member
I have a 3725 that is running Frame-Relay over ATM.The 3725 is an ABR between area0 and area3. The other side of the link is an 1841 which is also in area3.I have configured both links to ip ospf network point-to-point. Below is my configuration on both links. If I do a clear ip ospf process on the 3725 both adjacency states come to full. But after the 40 second timer comes around the 1841 re-initializes the OSPF process and it goes through exchanging LS updates but the 1841 gets caught into Loading stage while the 3725 show FULL. Here is the error I get once the 40 second dead timer runs. This happens on both sides of the link for an error. I have checked duplicate routerid's
Cannot see ourself in hello from 1.1.1.162 on ATM1/0.41, state INIT
OSPF: Build router LSA for area 3, router ID 1.1.1.9, seq 0x8000187E
process 100
I have tried configuring these a nonbroadcast links and same issue.
Cisco 3725
interface ATM1/0.41 point-to-point
description 233478 VCI 41
ip address 10.30.1.161 255.255.255.252
ip ospf priority 100
ip ospf mtu-ignore
ip ospf 100 area 3
no snmp trap link-status
pvc 1/41
vbr-nrt 1540 1540
encapsulation aal5snap
router ospf 100
log-adjacency-changes
no capability lls
area 0 authentication message-digest
summary-address 172.28.0.0 255.255.240.0
redistribute connected subnets
redistribute static metric 100 subnets
network 10.30.1.192 0.0.0.3 area 3
network 10.30.10.0 0.0.0.15 area 0
Cisco 1841
interface Serial0/0/0
no ip address
encapsulation frame-relay IETF
service-module t1 timeslots 1-24
frame-relay lmi-type ansi
interface Serial0/0/0.1 point-to-point
ip address 10.30.1.162 255.255.255.252
ip ospf priority 0
ip ospf mtu-ignore
ip ospf 100 area 3
frame-relay interface-dlci 17
router ospf 100
no capability lls
Edison Ortiz
Your overall config looks good. The only thing missing would be hard-coding a router-id under the ospf routing process. Weird things can happen with a missing or incorrect router-id.
If you don't hard-code the router-id, it should randomly pick from the highest loopback address but that's the only suggestion I can give... give it a try :).
HTH,
__
Edison.
Thanks for your response. I hardcoded the router-id and same issue. Here is the full error log. Router ID 1.1.1.9 is the 3725 and 1.1.1.162 is the 1841
eb 4 14:06:00.206: OSPF: Rcv hello from 1.1.1.9 area 3 from Serial0/0/0.1 10.30.1.161
Feb 4 14:06:00.206: OSPF: Cannot see ourself in hello from 1.1.1.9 on Serial0/0/0.1, state INIT
Feb 4 14:06:00.206: OSPF: Send immediate hello to nbr 1.1.1.9, src address 10.30.1.161, on Serial0/0/0.1
Feb 4 14:06:00.206: OSPF: Send hello to 224.0.0.5 area 3 on Serial0/0/0.1 from 10.30.1.162
Feb 4 14:06:00.206: OSPF: End of hello processing
Feb 4 14:06:00.706: OSPF: For next LSA generation - wait : 5000ms next: 5000ms
Feb 4 14:06:00.706: OSPF: Build router LSA for area 3, router ID 1.1.1.162, seq 0x8000000D
Multicast allowed on this link? Try using unicast instead with the neighbor command under the routing process.
I was able to ping the OSPF multicast address of 224.0.0.5 and got this response on both ends. From 3725
rtr#ping 224.0.0.5
Sending 1, 100-byte ICMP Echos to 224.0.0.5, timeout is 2 seconds:
Reply to request 0 from 10.30.1.162, 8 ms
From 1841
rtr#ping 224.0.0.5
Reply to request 0 from 10.30.1.161, 96 ms
I have tried making both a non-broadcost link under each interface and configuring the neighbor statement under the OSPF process with no luck still. I don't believe I can leave the ip ospf network point-to-point and configure the neigbor command correct?
