OSPF broadcast mode w/ inverse-arp
jdevoll
I am seeing some behavior out of OSPF in non_broadcast mode that I would not expect. I haven't identified any neighbors on any interfaces, yet the spokes are forming full adjacencies with the hub. I do have inverse-arp enabled on my frame switch and I suspect that inverse-arp is 'enabling' this behavior. Can you please explain the what and the why of what I am seeing?
------------------ HUB -----------------
interface Serial1/0
description *** to Frame Switch S5 ***
ip address 172.31.11.4 255.255.255.0
encapsulation frame-relay
no fair-queue
router ospf 1
log-adjacency-changes
network 172.31.11.0 0.0.0.255 area 0
------------------Spoke1----------------
interface Serial0/0
ip address 172.31.11.1 255.255.255.0
frame-relay lmi-type cisco
router ospf 1
-----------------Spoke2-----------------
interface Serial0/0
ip address 172.31.11.2 255.255.255.0
end
router ospf 1
spoke2#show ip ospf nei
Neighbor ID Pri State Dead Time Address Interface
172.31.11.4 1 FULL/BDR 00:01:48 172.31.11.4 Serial0/0
spoke2#show ip ospf int
Serial0/0 is up, line protocol is up
Internet Address 172.31.11.2/24, Area 0
Process ID 1, Router ID 172.31.11.2, Network Type NON_BROADCAST, Cost: 64
6 Replies 6
Just wondering did you have neighbor statements earlier then subsequently removed it. I have seen routers use the cached neighbor info to form ospf adjacency.
Sundar
Actually yes, I did have the neighbor statements listed previously. I'll re-load everything and see if I end up with the same behavior.
That's what I thought.
Let us know what the outcome is after the reload!!
Sundar
Jeremy, what did you find out?
You don't have to reboot. Issue the
clear ip ospf process
Edison Ortiz
Let's see the 'show frame map' and 'show ip os int bri' command from all routers involved.
