OSPF Commands
Juraj Papic
Level 5
Level 5
Greetings,
When you go to the new customer and you have to support/Troubleshoot  the network (in this case is OSPF) how will you proceed or what commands will you use in the network to know how ospf is working?
thanks.
10 Replies 10
pman
in case of Troubleshoot,
the following link should provide all the information you need according to the relevant scenario
please note the "show" commands in bold inside the rhombus
https://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/12151-trouble-main.html
What commend you looking for
there are commend for config
and commend for troubleshooting?
Juraj Papic
Level 5
Level 5
Hi all,
Im not looking for a specific command , I'm want to understand how other Ing approach to understand a new network cliente. I know you my request a HLD or LLD, but we know that in most of the cases that is not updated .
In my case I normally try to understand how the traffic flows, check if the traffic is symmetric or asymmetric .
Thanks.
Traceroute
this can help you in symmetric asymmetric issue.
if the traceroute show you two different hop in outbound direction
check if ospf have equal cost then it ok and traffic is symmetric
if the traceroute show  you two different hop in inbound direction
then traffic go and return from different router and this asymmetric
My main commands for looking at and troubleshooting OSPF are as follows:
sh ip ospf interface brief <- this shows you what interfaces are operating with ospf. This does not include passive interfaces I believe. If it does not show up here it will NOT form a neighbor adjacency
sh ip ospf neighbors <- this shows you which interfaces have established neighbor adjacencies along with DR/BDR information on that link if applicable
show ip protocols <- this will show stuff like passive interface, reference bandwidth, networks advertising for and other metrics
sh ip ospf databse <- this is the OSPF database and everything it knows about the current structure of the network. This probably has the most information but is the most cumbersome to understand, especially in a new network.
There are many commands, these are just my go-to commands for tshooting and understanding.
Hope that helps
-David
Deepak Kumar
I think, no one have a direct answer for this and if I would say check OSPF database for whole network seating on a single router/switch, can you do it?
So, don't try to fly a flight without going on the runway. Try to figure about what is issue? If you are not sure how to identify than i would recommend to go with a flow chart from top to down or down to top. Think about it, Which flow chart is good for your position.
https://petri.com/ccnp-tshoot-cisco-troubleshooting-techniques/
however this guide will help you:
https://www.learncisco.net/courses/icnd-2/implementing-a-multiarea-ospf-solution/troubleshooting-multiarea-ospf.html
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Jon Marshall
First thing is to look at the IP routing table and work out what subnets are where ie. forget about the specific routing protocol in use until you understand the L3 layout.
Then you can start to look at the OSPF specifics with the commands and advice provided here.
Jon
Joseph W. Doherty
Well, when troubleshooting a network issue, I would first like to gather as much information about the "issue" as possible.  This before I would investigate whatever routing is configured/used, whether implicit, static or using an IGP (like OSFP),
So you would wait for the first problem before you try and work out how the network works ?
You like a challenge then.
Jon
I do like challenges, but laugh, I think I focused too much on OP's "troubleshooting".  I.e. before I troubleshoot, I do like to know what the "trouble" is.
Troubleshooting aside, though, OP also mentioned supporting a new customer network.  Also, again, I ran by that (supporting) to troubleshooting.
For supporting a new network, generally I like to start with a diagram of the network, check its accuracy and "learn" the network, including things like what IGP is being used, and for something like OSPF, including, yes, ". . . how ospf is working?", in the sense of OSPF topology, OSPF areas, kinds of areas, ABR summarizations, etc.  "Learning" the network, though, often includes much. much more than what is the IGP and how it's set up.
Unfortunately, there are times, especially when working with a "new" (to you) network, where this is some "problem" and you need to immediately start troubleshooting.  In such cases, I start with "what's been changed last?" (often the source of a new problem) and proceed to further investigate/learn network functions that might cause the kind of trouble being reported.  Again, I like to learn as much about the "trouble", as the nature of the "trouble" often helps in directing your troubleshooting.
