OSPF convergence
cisco8887
Level 2
Level 2
Hi Guys,
I am working on something and need a fairly quick answer and cannot run a lab and test.
How does OSPF convergence work when on link fails? it doens't store any backup path like eigrp does it ?
it will recalculate the path.
Is there a way to have a redandunt route in place to quickly failover ?
if not does anyone know how long the convergence take using SPF algorithm ? is my question like how long is a peice of string ?
5 Replies 5
David_Che
If you configure LFA feature, OSPF will be immediate to switch-over to the backup route.
many thannks, does bgp support a multiple backup route like eigrp ?
BGP is more flexible than OSPF it can have multiple paths installed in the BGP table waiting to take over from the primary , depending on your design and what your trying to do there are a few ways to achieve it , one way below is install command
bgp additional-paths install
http://www.cisco.com/c/en/us/td/docs/ios/iproute_bgp/command/reference/irg_book/irg_bgp1.html#wp1117217
With BGP though its best not to have a redundant path as it will be wan and costly to have sitting there so usually you would load share the links so there all used at once and at the same time use bgp path attributes so there backed up between each wan link
many thanks, so what you are saying is there will be no convergence ?
if you use ospf and tune the metric to load balance across three links, if one dies, does it trigger spf algorithm ? would you loose connectivity ?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Normally, it recomputes a new best path.
Normally, no.
Normally, no, but if you have two equal cost paths, besides using both normally, it will just use the remaining one.
Laugh, yes much like how long is a piece of string.
Many variables are involved.  Convergence time is impacted by design and configuration settings.  The latter, when properly set, can lead to pretty quick OSPF convergence with a link failure.  See http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Campus/routed-ex.html#wp998679
