OSPF cost
acbenny
Hi all,
There are three diagram, Does the routing table of bottom routing is correct ?
7 Replies 7
Danilo Dy
where?
sdoremus33
Level 3
Level 3
Please repost original argument with diagram. Thanks
Attach diagram
The diagram does not include the cost of the links. We can't give answer how the cost change from 30 to 40 to 50.
Assumption;
All link cost is 10 except the link between the router in the center and the bottom which is 20.
A. OSPF cost 30
The path is the vertical line between the top and the bottom router = 10 + 20 = 30
B. OSPF cost 40
Zigzag line in the left = 10 + 10 + 10 + 10 = 40
C. OSPF cost 50
Zigzag lin in the right plus the bottom line = 10 + 10 + 10 + 20 (or 10 + 10 + 10 + 10 + 10 +10) = 50
Please complete your diagram. Put OSPF cost in all the lines and put a name in all the routers.
Sorry, All links are ethernet links which i think ospf cost is 10
Depends, it could be.
1. Ethernet
2. FastEthernet
3. GigabitEthernet
4. Manually configured the ospf cost to manipulate route path (recommended)
So its still best to put the cost for the links in the diagram.
johnakeating
I have found a list of all the default costs here.
http://www.learnios.com/viewtopic.php?f=85&t=89
