OSPF cost
arun.patro
Hi frnds, have one doubt..
Wht will be the cost of ckt having bandwidth 1 GB.
I reffered some docs.. bit confused. as it is 1 for 100 MB ckts as per the formula 10^8/bandwith.
pls suggest.
Thanks.
cadet alain
It will still be 1 so you'll have to change cost on interface with ip ospf cost command or change the reference-bw to something higher than 10 exp8.
Regards.
Alain.
cadet alain
Regards.
Alain.
Thanks Alain
