OSPF did not creat a neighbors relationship
solmix
hi
i am trying to work on my project on gns3 I do everything right but i can't see the OSPF neighbors relationship  between my router and Layer 3 switch
Topology and configuration as follows
Router 1 connects to L3S on interface Eth1/0
L3S connects to Router 1 on interface Eth 0/0
Router 1 configuration file
interface Ethernet1/0
ip address 172.58.10.3 255.255.255.240
ip ospf authentication message-digest
ip ospf message-digest-key 1 md5 12345
full-duplex
router ospf 100
router-id 2.2.2.2
log-adjacency-changes
area 0 authentication message-digest
passive-interface default
no passive-interface Ethernet1/0
no passive-interface Ethernet1/1
network 172.58.10.0 0.0.0.0 area 0
network 172.58.20.0 0.0.0.0 area 0
L3S conf file
interface Ethernet0/0
no switchport
ip address 172.58.10.1 255.255.255.240
router ospf 100
router-id 1.1.1.1
network 192.168.10.0 0.0.0.255 area 0
network 192.168.20.0 0.0.0.255 area 0
network 192.168.30.0 0.0.0.255 area 0
network 192.168.40.0 0.0.0.255 area 0
network 192.168.50.0 0.0.0.255 area 0
network 192.168.60.0 0.0.0.255 area 0
Looking forward to it thank you
make the changes marked in bold:
full-duplex
router ospf 100
router-id 2.2.2.2
--> network 172.58.10.0 0.0.0.255 area 0
--> network 172.58.20.0 0.0.0.255 area 0
L3S conf file
no switchport
router ospf 100
router-id 1.1.1.1
--> no passive-interface Ethernet0/0
full-duplex
router ospf 100
router-id 2.2.2.2
L3S conf file
no switchport
router ospf 100
router-id 1.1.1.1
thank you very much for you kind replay  it works perfectly
Hello
Suggest to remove area/interface authentication then try to establish ospf adjacency’s  when you do have the adjacency’s append authentication.
If you cannot turn authentication off then do so at the interface level and test again
int x/x
ip ospf authentication null
Kind Regards
Paul
Joseph W. Doherty
BTW, both Georg and Paul suggest using an OSPF mask of 0.0.0.255 but as your interface address masks are 255.255.255.240, you might match other interfaces on the same router.  (I.e. any that fall under the /24.)  If that is what you intend, that's fine, but otherwise I would suggest you either match the interface's IP or its specific subnet size.  The former would use an OSPF mask of 0.0.0.0 (and the interface's IP) and the latter an OSPF mask of 0.0.0.15. (and the interface's network prefix)
Another option, with later Cisco IOS OSPF implementations, is to use the interface command "ip ospf process-id area area-id".  Instead of the network statements.
