OSPF different default routes for different areas
hagnerfaxed
Site 1 Router A: ABR (Area 0, Area 1) >>>>>ISP A and ISP B <<<<< Site 2 Router A: (Area 1)
Five Layer 3 switches connected to Site 1 Router A. Five Layer 3 switches connected to Site 2 Router A
Site 1 and Site 2 are connected over 2 ISP using 2 tunnels (192.168.1.0 /30) and (192.168.2.0 /30)
Site 1 Router A is configured with default routes to ISP and ISP2 and default information originate
The problem is that the default routes advertised to Site 2 Router A (Area 1) are traversing the tunnels instead of using direct connections to ISP A and ISP B
r/Cisco - OSPF different default routes for different areas
My question is, is it possible to assign different default routes to different area (Site 2 Router A) so that the default traffic will not go through the tunnels to backbone area first then to the ISP?
Thank you so much for your advice.
there are many solution
1- use front door to separate the IGP run over Tunnel and the IGP/Static route use by router to connect to ISP
2- use NSSA for IGP over tunnel this area will prevent any LSA5 (default LSA5)
3- use BGP over tunnel and use route-map to prevent default route advertise from one site to other site
MHM
Hello
Can you share a topology diagram..
Kind Regards
Paul
Giuseppe Larosa
Hello @hagnerfaxed ,
Your Site 2 Router A should have static default routes to ISP A, ISP B with AD < 110  ( default OSPF AD) and this will fix your issue.
Either you have floating static defaul routes with AD > 110 or you have only specific routes for remote public IP address(es) of Site 1 Router A.
As suggested making OSPF area 1 of type NSSA will block the sending of LSA type 5 over the two tunnels, however if these default LSA are used in the Site 2 Router A this means they are preferred over existing static default routes as I have explained above.
Hope to help
Giuseppe
