Ospf Distance
ccobtn
On Ospf is it possible to increase cost/distance for specific external address type5/7, without increase all the external addressees as this can be done “distance ospf external xxx” .
I’m running Ospf and Rip with overlapping IP address hence I want to make router r3 to prefer routes from the Rip r4 for this specific address. This is so that all the request from user LAN to 10.net should via r4 and if the 10.Net is down, request is directed via r2. i have attached network diagram
thisisshanky
Level 11
Level 11
If the number of external routes are less, you could use the following command instead.
distance
Define the routes in the ACL which you want to apply the distance.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
What would be the src address "ip address to be suppressed"?. ACL "Standard or extended".
