OSPF External Route Selection
goldpartner
On Router-A and Router-B,configure area 0 and area 1 as follows:
Router-A:
    area 0:10.5.5.5
    area 1:10.4.4.4
Router-B:
    area 0:10.5.5.6
    area 1:10.4.4.5
On Router-A, redistribute an external route into OSPF, so Router-A is an ASBR.
Question: On Router-B, what is the next hop of the external route above,10.5.5.5 or 10.4.4.4? Why?
15 Replies 15
#show run
Building configuration...
Current configuration : 1737 bytes
upgrade fpd auto
version 15.0
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
redundancy
ip tcp synwait-time 5
interface FastEthernet0/0
ip address 10.0.0.1 255.255.255.0
duplex half
interface Serial1/0
no ip address
shutdown
serial restart-delay 0
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface FastEthernet2/0
ip address 100.0.0.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet2/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet3/0
ip address 200.0.0.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet3/1
no ip address
shutdown
duplex auto
speed auto
router ospf 10
log-adjacency-changes
redistribute static subnets
network 100.0.0.0 0.0.0.255 area 0
network 200.0.0.0 0.0.0.255 area 1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 3.3.3.3 255.255.255.255 100.0.0.3
no cdp log mismatch duplex
control-plane
mgcp fax t38 ecm
mgcp behavior g729-variants static-pt
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R1#
R2#show run
Current configuration : 1655 bytes
upgrade fpd auto
version 15.0
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
redundancy
no ip address
shutdown
duplex half
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
ip address 100.0.0.2 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip address 200.0.0.2 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router ospf 10
no ip http server
control-plane
mgcp fax t38 ecm
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
