DMVPN Tunnel
beta_admin66
I want to build a DMVP tunnel connection. One router is the hub, the another router is spoke. An ISP router is between the hub and the spoke router.
I can not ping the tunnel endpoint from the hub to spoke and the spoke to the hub.
The tunnel interface is down on the spoke router.
Here is the configuration of the tunnel connection, the gigabit connection and the routes:
R1-HUB#show run interface tunnel 1
Building configuration...
Current configuration : 292 bytes
interface Tunnel1
ip address 10.20.10.1 255.255.255.240
no ip redirects
ip mtu 1380
ip nhrp authentication xxx
ip nhrp network-id 1666
ip nhrp holdtime 10800
ip nhrp redirect
ip tcp adjust-mss 1340
tunnel source GigabitEthernet0/0
tunnel mode gre multipoint
tunnel key 1666
interface GigabitEthernet0/0
ip address 172.16.11.1 255.255.255.0
duplex auto
speed auto
ip route 172.16.31.0 255.255.255.0 172.16.11.2
R2-SPOKE#show run interface tunnel 1
Current configuration : 291 bytes
interface Tunnel1
bandwidth 10000000
ip address 10.20.10.4 255.255.255.240
ip mtu 1380
ip nhrp map 10.20.10.1 172.16.11.1
ip nhrp nhs 10.20.10.1
keepalive 10 6
tunnel source GigabitEthernet0/1
tunnel destination 172.16.11.1
interface GigabitEthernet0/1
ip address 172.16.31.1 255.255.255.0
duplex auto
speed auto
ip route 172.16.11.0 255.255.255.0 172.16.31.2
balaji.bandi
Do you have reachability between device - ping and test it
Follow some troubleshooting tips :
https://www.cisco.com/c/en/us/support/docs/security/dynamic-multipoint-vpn-dmvpn/111976-dmvpn-troubleshoot-00.html
worth doing debug see what is the issue.
BB
It direct connect' so ping use source IP.
That all what you need
There are a few Phases to DMVPN which require slightly different configurations. It looks like you are implementing Phase 3 on the HUB with the ip nhrp redirect command and Phase 1 on the Spoke with the Source/Destination explicitly configured as well as no ip nhrp shortcut command on the Spoke router. You also need to configure the same Network ID AND tunnel key on all devices needing to communicate. However you only need the tunnel key if more than 1 DMVPN domain is using the interface as the same source address. Can you try the config below? I bolded the config changes.
interface Tunnel1
no ip redirects
ip mtu 1380
ip nhrp redirect
tunnel key 1666
duplex auto
speed auto
interface Tunnel1
bandwidth 10000000
ip mtu 1380
keepalive 10 6
tunnel key 1666
-David
