OSPF hello process occupy too much CPU usage !!
chungandrew
I have a Catalyst 6509 connect to another switch using two giga port bundled by a layer2 Etherchannel , then I create the same vlan within these two switch and enable OSPF in the layer 3 vlan interface . However , I often found the OSPF hello process occupy too much CPU usage then cause the OSPF neighbor up/down , I am wondering what will be the most possible cause to make it happen .
Roberto Salazar
Level 8
Level 8
High CPU will cause more than just OSPF adjacency. Have you looked at the show proc cpu and determined which process is hogging the cpu? Is the new vlan you created the only vlan the OSPF is running on? Is this a Native IOS or Hybrid? Have you checked the log of the switch/MSFC? anything interesting?
"show process cpu" command display :
CPU utilization for five seconds: 0%/0%; one minute: 34%; five minutes: 40%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
111 23615884 478191301 49 18.63% 5.29% 5.01% 0 IP Input
120 49543536 267899596 184 21.19% 6.63% 6.57% 0 OSPF Hello
It indicate "IP Input" and "OSPF Hello" process almost take up the whole CPU resource .
Ctatalyst 6509 is running with two SUP-720 configured in "SSO" redundancy mode (Native IOS)
Hmm, for five secs section the cpu is 0% but there are process that has 18% and 21%. For troubleshooting purposes, have you try shutting down one of the gig port in that channel, did the cpu subsided? Is the high cpu only occurs when you enable that interface vlan? does the cpu go down when that new interface vlan is admin down? can you verify the spanning tree for that vlan, make sure the right root is the root for that vlan.
Below is my configuration for your reference , I am wondering if the problem is under the etherchannel , should I use the layer 3 etherchannel to act as OSPF interface ?
spanning-tree mode mst
no spanning-tree optimize bpdu transmission
spanning-tree vlan 1-4094 priority 0
spanning-tree mst 0 priority 0
port-channel load-balance src-mac
redundancy
mode sso
main-cpu
auto-sync running-config
auto-sync standard
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
interface Port-channel2
no ip address
switchport
switchport trunk allowed vlan 118,526-533,760,4088,4092
switchport mode trunk
switchport nonegotiate
interface Port-channel3
no ip address
switchport
switchport trunk allowed vlan 117,128,524,525,754,761,4089,4092
interface GigabitEthernet1/2
no ip address
switchport
channel-protocol lacp
channel-group 2 mode active
interface GigabitEthernet1/3
no ip address
switchport
channel-group 3 mode active
interface GigabitEthernet2/2
no ip address
switchport
interface GigabitEthernet2/3
no ip address
switchport
no cdp enable
interface FastEthernet9/48
no ip address
switchport
switchport access vlan 4092
switchport mode access
interface Vlan1
no ip address
interface Vlan114
no ip address
priority-group 14
interface Vlan117
no ip address
interface Vlan119
no ip address
interface Vlan129
no ip address
interface Vlan130
no ip address
interface Vlan136
no ip address
interface Vlan138
no ip address
interface Vlan530
no ip address
interface Vlan754
no ip address
interface Vlan756
no ip address
interface Vlan757
no ip address
interface Vlan758
no ip address
interface Vlan759
no ip address
interface Vlan773
no ip address
interface Vlan1031
ip address 192.168.42.50 255.255.255.0
interface Vlan4076
ip address 172.26.254.153 255.255.255.252
interface Vlan4087
ip address 172.26.254.65 255.255.255.252
interface Vlan4088
ip address 172.26.254.57 255.255.255.252
interface Vlan4089
ip address 172.26.254.53 255.255.255.252
interface Vlan4090
ip address 172.26.254.50 255.255.255.252
interface Vlan4091
ip address 172.26.254.141 255.255.255.252
interface Vlan4092
ip address 172.26.120.190 255.255.255.192
priority-group 1
router ospf 1
router-id 172.26.120.190
log-adjacency-changes
network 172.22.67.0 0.0.0.255 area 2
network 172.26.120.190 0.0.0.0 area 2
network 172.26.120.0 0.0.0.255 area 2
network 172.26.121.0 0.0.0.255 area 2
network 172.26.254.48 0.0.0.3 area 2
network 172.26.254.52 0.0.0.3 area 2
network 172.26.254.56 0.0.0.3 area 2
network 172.26.254.64 0.0.0.3 area 2
network 172.26.254.140 0.0.0.3 area 2
network 172.26.254.152 0.0.0.3 area 2
ip route 172.22.0.0 255.255.0.0 172.22.67.254
priority-list 14 interface Vlan114 medium
