Ospf help
haiqalimanshah2
I have problem with ospf idk what i did
I can ping R1 to all except Lo4 area 40 same goes to other all have same problem where Lo4 cant be ping
R1
spanning-tree mode pvst
interface Loopback0
ip address 172.16.1.1 255.255.255.0
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
bandwidth 64
ip address 172.16.12.1 255.255.255.0
clock rate 128000
interface Serial0/0/1
no ip address
clock rate 2000000
shutdown
interface FastEthernet0/1/0
switchport mode access
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 172.16.1.0 0.0.0.255 area 0
network 172.16.12.2 0.0.0.0 area 0
network 172.16.12.0 0.0.0.255 area 0
ip classless
ip flow-export version 9
R2
interface Loopback0
ip address 172.16.2.1 255.255.255.0
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
bandwidth 64
ip address 172.16.12.2 255.255.255.0
bandwidth 64
ip address 172.16.23.2 255.255.255.0
clock rate 128000
interface Serial0/1/0
no ip address
clock rate 2000000
shutdown
interface Serial0/1/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
network 172.16.2.0 0.0.0.255 area 0
network 172.16.23.0 0.0.0.255 area 0
ip classless
interface Vlan1
no ip address
shutdown
router ospf 1
ip classless
R3
interface Loopback0
ip address 172.16.3.1 255.255.255.0
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
no ip address
clock rate 2000000
shutdown
bandwidth 64
ip address 172.16.23.3 255.255.255.0
bandwidth 64
ip address 172.16.34.3 255.255.255.0
clock rate 128000
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
area 34 virtual-link 172.16.4.1
network 172.16.3.0 0.0.0.255 area 34
network 172.16.34.0 0.0.0.255 area 34
network 172.16.4.0 0.0.0.255 area 40
ip classless
R4
interface Loopback0
ip address 172.16.4.1 255.255.255.0
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
bandwidth 64
ip address 172.16.34.4 255.255.255.0
no ip address
clock rate 2000000
interface Vlan1
no ip address
shutdown
router ospf 1
area 34 virtual-link 172.16.34.3
ip classless
your virtual link does not look right. On R4, whatever you configure the VL to, needs to be in area 0. Make the changes marked in bold:
R3
router ospf 1
--> network 172.16.3.0 0.0.0.255 area 0
R4
--> area 34 virtual-link 172.16.3.1
No need any link in area 0
Only the IP you use in virtual link is not correct. Correct it.
Note :- it better to use IP that ospf use as router ID. So double check if rputers use LO as router-id
MHM
Hello @haiqalimanshah2 ,
on R4 change:
router ospf 1
Regards, LG
*** Please Rate All Helpful Responses ***
@liviu.gheorghe @MHM Cisco World I stand corrected, you are both right. The loopback of R3 does not need to be in area 0.
