Processor type and forwarding performance
kaziijaz.rashid
Hi All,
I would like to know the processor type and forwardign performance of Cisco 3845 IAS router.
5 Replies 5
amit-singh
Level 8
Level 8
Hi Friend,
Cisco 3845 has 500,000 PPS fast switching capacity and a throughput of 256 Mbps.
The processor type info I am unable to find out for you.
HTH,
-amit singh
Can I ask how you've confirmed the max throughput is 256mb?. I can't find any reference on CCO to clarify this. In otherwords, what performance should I expect in/out the gigabit ports for straight routed traffic.
In the Q&A it says "performance of 350-500 Kpps in light service environments with 64 byte packets".
500Kpps x 64bytes = 256Mbps
Whether you'd get this in practice is another matter - see the Miercom report:
http://www.cisco.com/application/pdf/en/us/guest/products/ps5856/c1244/cdccont_0900aecd8058608c.pdf
Andrew.
So at 1500byte packets, we could expect the full 1gb through the LAN interface? It's just that I can't find this confirmed anywhere, other than assuming it would perform at full rate in those cases. I know thats not general real life traffic, but I'm thinking of network archoves etc. Thanks.
