ospf load balancing
bapatsubodh
hi
we are facing load balancing problem.
Details of network set up is given in attached msword document.
Any suggestions..
Thanks in advance
Subodh
parthibanp
Try enabling per packet load balancing on the involved interfaces (seria&ethernet) on all the rotuers involved.
Amit Singh
Subodh,
Can you please post the config from both R1 and R3 and also "show ip route "
-amit singh
Dear Mr. Singh,
all routers R1, R2, R3, and R 4 are all 7507 series routers having more that 800 rouets. SO i think it's practically difficult to caputre o/p or sh ip route. Can i post any particular routes , wherein router shows two paths of equal cost to destinations.
Pls. ack back.
( Also I will try per packet switching if possible as mentioned in second reply )
Thanks and Regards.
Subodh
parthibanp
