OSPF MD5 password
tahseen12
OSPF md5 authentication passwords can be decrypted or can be used by copying and paste inspite using md5 algorithm which is same as enable secret
Is it a bug Please explain??
Edison Ortiz
The md5 algorithm is used when the password is sent over the wire to a neighbor OSPF device. The password seen in the running config, however, does not protect the password at the md5 level.
HTH,
