OSPF Multiple Areas Configuration
violetta1405
Hi, My name is Quan. I am new to OSPF and dynamic routing.
I've been learning about RIPv2 configurations and OSPF configurations.
While i am doing in this OSPF Multiple Areas lab
I had a problem regarding the routing table doesn't show results as I thought. HUE router and CANTHO router doesn't have O*E2 (default route) even though I configured everything correct then I asked chat GPT to help me then it guided me to turn on Vlan1 for SAIGON and DANANG and it fixed the problem
Here is my configuration:
hostname HAIPHONG
ip dhcp excluded-address 192.168.3.1
ip dhcp pool LAN1
network 192.168.3.0 255.255.255.192
default-router 192.168.3.1
dns-server 8.8.8.8
interface FastEthernet0/0
ip address 192.168.3.1 255.255.255.192
duplex auto
speed auto
interface FastEthernet0/1
ip address 1.2.3.5 255.255.255.0
duplex auto
speed auto
interface Serial0/3/0
ip address 192.168.3.129 255.255.255.252
clock rate 2000000
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 192.168.3.0 0.0.0.63 area 3
network 192.168.3.128 0.0.0.3 area 3
default-information originate
ip classless
ip route 0.0.0.0 0.0.0.0 1.2.3.4
hostname HANOI
ip dhcp excluded-address 192.168.3.65
ip dhcp pool LAN2
network 192.168.3.64 255.255.255.192
default-router 192.168.3.65
dns-server 8.8.8.8
ip address 192.168.3.65 255.255.255.192
duplex auto
speed auto
ip address 192.168.0.131 255.255.255.248
duplex auto
speed auto
ip address 192.168.3.130 255.255.255.252
interface Vlan1
no ip address
shutdown
router ospf 1
network 192.168.3.64 0.0.0.63 area 3
network 192.168.0.128 0.0.0.7 area 0
ip classless
ip flow-export version 9
hostname DANANG
ip dhcp excluded-address 192.168.0.1
ip dhcp pool LAN3
network 192.168.0.0 255.255.255.192
default-router 192.168.0.1
dns-server 8.8.8.8
ip address 192.168.0.1 255.255.255.192
duplex auto
speed auto
ip address 192.168.0.130 255.255.255.248
duplex auto
speed auto
ip address 192.168.1.66 255.255.255.252
interface Vlan1
no ip address
shutdown
router ospf 1
network 192.168.0.0 0.0.0.63 area 0
network 192.168.1.64 0.0.0.3 area 1
ip classless
hostname SAIGON
ip dhcp excluded-address 192.168.0.65
ip dhcp pool LAN4
network 192.168.0.64 255.255.255.192
default-router 192.168.0.65
dns-server 8.8.8.8
ip address 192.168.0.65 255.255.255.192
duplex auto
speed auto
ip address 192.168.0.129 255.255.255.248
duplex auto
speed auto
ip address 192.168.2.65 255.255.255.252
interface Vlan1
no ip address
shutdown
router ospf 1
network 192.168.0.64 0.0.0.63 area 0
network 192.168.2.64 0.0.0.3 area 2
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LAN5
network 192.168.1.0 255.255.255.192
default-router 192.168.1.1
dns-server 8.8.8.8
ip address 192.168.1.1 255.255.255.192
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
ip address 192.168.1.65 255.255.255.252
clock rate 2000000
interface Vlan1
no ip address
shutdown
router ospf 1
network 192.168.1.0 0.0.0.63 area 1
hostname CANTHO
ip dhcp excluded-address 192.168.2.1
ip dhcp pool 192.168.2.1
ip dhcp pool LAN6
network 192.168.2.0 255.255.255.192
default-router 192.168.2.1
dns-server 8.8.8.8
ip cef
no ipv6 cef
license udi pid CISCO2811/K9 sn FTX1017ICN7-
spanning-tree mode pvst
ip address 192.168.2.1 255.255.255.192
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Serial0/1/0
ip address 192.168.2.66 255.255.255.252
clock rate 2000000
interface Vlan1
no ip address
shutdown
router ospf 1
network 192.168.2.0 0.0.0.63 area 2
hostname ISP
ip dhcp excluded-address 6.9.6.9
ip dhcp excluded-address 6.9.6.10
ip dhcp pool Internet
network 6.9.6.0 255.255.255.0
default-router 6.9.6.9
dns-server 8.8.8.8
ip cef
no ipv6 cef
description LINK TO DSL CLOUD
ip address 1.2.3.4 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
interface FastEthernet0/0/0
switchport access vlan 69
switchport mode access
spanning-tree portfast
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Vlan1
no ip address
shutdown
interface Vlan69
mac-address 0009.7c49.9e01
ip address 8.8.8.9 255.255.255.0
router rip
ip classless
ip route 0.0.0.0 0.0.0.0 1.2.3.5
11 Replies 11
Im not sure what turning on VLAN 1 did to fix anything. Glancing at your config it looks fine.
Can you provide the output of the following commands on the routers:
show ip ospf neigh
sh ip route ospf
-David
Here is the result of all 6 routers:
M02@rt37
Hello @violetta1405
On HAIPHONG router, do you succeed to ping IP 1.2.3.4 ?
Please show outputs that David ask for. Thanks a lot.
Best regards
I successfully ping the ISP interface with the ip of 1.2.3.4
Joseph W. Doherty
Attach your PT file to OP.
How do I attach pkt file to the post? It doesn't allow me to attach it
Thank you.
I zipped the pkt file. I wonder if I didn't have O*E2 becauses I configure dhcp pool on router or I didn't fully configure before connecting these devices with cables
Joseph W. Doherty
I had a problem regarding the routing table doesn't show results as I thought. HUE router and CANTHO router doesn't have O*E2 (default route) . . .
When I bring up your recently attached PT file:
Seems to be present on both those routers, for me.
What version of PT are you running?
I'm running 8.2.2.0400.
I think i am running on 8.2.1
btw I closed it and checked and yeah it appears the O*E2 now
maybe the problem was I haven't fully configured before connecting these devices using cables so it contradicts ?
Possibility, or maybe you didn't allow enough time for PT's OSPF to fully converge?  (I often use the time acceleration button to eliminate waiting for devices to boot, STP to converge, etc.)
BTW, you might find PT's version by using the menu's help about.
Hmn weirdly I took an amount of time checking for wrong configurations tho so might be time is not the problem but thanks for the tip
