OSPF neighborship flapping
iores
Level 3
Level 3
I had OSPF neighborship flapping which I have solved. However, I have few questions.
The logs I kept getting were "....from full to down, neighbor down: dead timer expired.".
The main culprit was ACL on the port with entry denying destination IP 224.0.0.5.
How did the adjacency come up in the first place with such ACL?
8 Replies 8
Joseph W. Doherty
Cannot say for sure without seeing all relevant config on both routers, but OSPF also uses 224.0.0.6.(?)
DR and BDR are members of 224.0.0.6, right? The neighborship was formed between SVIs. The router which was elected as DR, had ACL on physical interaces on inbound direction. There are only two devices on the segment.
Recall, that's what .6 supports, so allowing that, but not .5 might be why it established an adjacenty it could not sustain.
But if hello packets are multicast, then the adjacency shoudn't come up in the first place? The device with ACL would deny those packets.
Could it be that device without ACL, send its hello packets first, and when neighboring device receive them, the communication turns to unicast. Then when adjacency comes up, the hello packets are sent to 224.0.0.5 again?
Honestly, don't know that level of detail off the top of my head.
The reason I even mentioned .6 (with a question mark), assuming .5 is fully blocked, some OSPF information has to be getting though for any adjacency attempts, or so I would think.
In the real world, I presume blocking a defined destination IP, or packet type, used by a routing protocol, isn't a "good thing".  I don't worry about what may or may not work, I just want to insure, initially, nothing the protocol is expecting is blocked without good reason.
In other words, your question, to me, is only of "academic" interest.  That doesn't mean you cannot pursue it, but what's the final benefit?  Whatever you "discover" should then be checked against the OSPF RFCs, to see if the results make sense, right?  Again, knowing exactly the impact of blocking one of OSPF's defined packet types, benefits us how?  (Well, other than seeing the same issue again, and perhaps more quick identification of the cause.  [Which is actually careless or ignorance of OSPF needs?  I.e. how did such a configuration get applied?])
In my experience, there's enough other "real" OSPF issues that you can stub your toe on, without understanding all of OSPF operational workings without blocking one of its defined packet types.
Possibly the point I'm making isn't clear.  I.e. knowing about 224.0.0.5 and 224.0.0.6 being used by OSPF is good, to avoid blocking either, but how worthwhile is it to know what will exactly happen if you block just one or the other?
Again, I don't mean to infer knowing such is in any way "bad" or even worthless, just that there's so much else to know about OSPF that can cause issues if you don't know specific OSPF design considerations.
Laugh, on these forums, someone presented an OSPF issue, which took me sometime to figure out, as it was a rather rare situation and OSPF changed its behavior between two RFCs.  Interestingly, Cisco supports using the old RFC or the newer RFC handling, but also uses different defaults based on the Cisco equipment (I recall Catalyst defaults to the older RFC, and Nexus to the newer RFC, which makes for a mess if you mix the two families and have to deal with this rare usage situation.)
Again, the forgoing is likely uncommon, but also, I think, more worthwhile than spending time on a question like yours, is learning what Cisco has done to its OSPF implementation, to "improve it", yet not necessarily how other implementations do it.  Or, things like, when Cisco introduced the OSPF iSPF feature, although I believe that now be eliminated, as Cisco believes it's no longer offers benefit, or . . .
Was the acl applied after the initial ospf adjacency(s) were formed, if so,  then the adjacency(s) could have stayed formed until that is there was a further convergence occurred that tore them down  then as that time the acl would deny the reforming?
Kind Regards
Paul
The ACL was applied before OSPF configuration.
Hello
So in that case either the adjacency would have initially formed but then would begin to be torn down/re-establish after the hello/dead timers fail. just like you see in that log
Kind Regards
Paul
