OSPF NSSA
feroz syed
Level 3
Level 3
I have this ospf topology,Router 4 redistribute eigrp routes in to ospf, when i configure r2 and r5(area 2) as stub external type-5 lsa has been blocked and i have single route in database, so 0.0.0.0         2.2.2.2         56          0x80000001 0x0075C0, so i try router 2 become totally- stub area. now its blocked both type 3 and type 5 lsa n R5, this time i had only one single default route in router 5 *0 IA.  1) what is the use by making those area stub or totally sub ? just making route table and database small or any thing else ??
Now i configure rip network on Router 5 and try to redistribute n to ospf, it's show this error
*Dec 26 00:48:05.016: %OSPF-4-ASBR_WITHOUT_VALID_AREA: Router is currently an ASBR while having only one area which is a stub area.
This error indicate that can't have asbr on stub area  (bcoz of type 5 lsa blocked already) am right??.
Now R5 and R2 running as NSSA and R5 redistribute rip routes in to ospf.everything works great except one, i can't reach R4 eigrp network,Router 4,3 and 1 can able to pinging R5 rip network, and Router 2 (ABR) can ping R4 eigrp network.But i found answer on google that need to add default-information-originate command on Rotuer2 (ABR). Can anybody explain me why i should added that cmd and after add how it's able to ping R4 eigrp routes.
Any help would be very much appreciated
Rolf Fischer
Level 9
Level 9
Stub Areas save resources in terms of CPU, memory and network traffic by filtering out certain information and replacing them by a default-route. A potential drawback is loss of detail information if more than one exit-points exist, which could cause some suboptimal paths. In your topology there is only one exit-point, so it doesn't matter if you have 1000 exteral routes, all pointing to the same ABR, or simply one default-route, providing the very same information: The outside world is reachable through the ARB (R2) - just like leaving a dead-end street.
Correct. The concept of a NSSA was introduced to meet such requirements.
Unlike Stub Area Broder Routers, a NSSA Border Router does not inject a default route automatically, you have to configure it manually if needed (similar to Regular Areas):
area nssa default-information-originate [metric <0-16777214>] [metric-type <1-2>]
Rolf
Rolf Fischer
Level 9
Level 9
Rolf
