OSPF on a 3560CG
bakugo
Obviously not a production workload and very much just to see if I can make it work
I have a 3560CG as my core switch which does all the intervlan routing, with a default route up to a firewall for WAN bound traffic, works fine all good.
I have static routes on my firewall which point to the 3560 for traffic down to the VLANs.
Firewall supports OSPF, I'm seeing conflicting info on if the 3560CG does or doesn't, running IPBase (I'm fairly sure the non compact 3560 switches DO support it with IPServices, but that isn't an option on the C series and neither is changing the SDM profile)
There are only 4 routes and they very rarely require changing, so like I say I know there is no actual point to doing this, but I've never setup OSPF before so wouldn't mind trying it out to prove I can if the device supports it
Jaime Valencia
This is the collaboration forum, might want to move this post to a relevant area for your question
java
if this helps, please rate
