OSPF on Cisco router 4331 with internal switch module
MARTIN FUNKE
I have set up an internal switch in a cisco 4331 router with an internal connection with BDI interface on the router and interface vlan 20 on the switch module.
I have configured both interfaces with an ip address each within the same subnet. Ping is running from both sides.
On both sides I have configured ospf process 1 and the interfaces in area 42 with the network command.
I see some ospf hello packet sent and received on both sides but the neighborship wont come up.
w-lvn-dvs-lbme-k-sw-1#sh ip ospf nei
Neighbor ID     Pri   State           Dead Time   Address         Interface
172.16.18.80      1   DOWN/DROTHER       -        172.18.67.5     Vlan20
w-lvn-dvs-lbme-k-1#sh ip ospf nei
172.16.18.81      1   EXCHANGE/DR     00:00:37    172.18.67.6     BDI1
w-lvn-dvs-lbme-k-1#
Has anybody an idea what went wrong?
Best regards,
Martin Funke.
does the MTU match on each neighbor side ?
Richard Burts
There is not enough information here to be sure what is the issue. Can you post the configuration?
Rick
Rick
That is the solution. As soon as I adjusted the mtu size on the router the ospf neiborship came up.
Thank's a lot Mark.
ah great thats good , thanks for marking it may help someone else
