OSPF Priority
kirk.brookover
Is there a way to set OSPF priority at a global level or can you only do it by interface?
Thanks!
Jon Marshall
kirk.brookover@ch2m.com
Thanks!
Kirk
Only by interface as far as i know because each interface will peer with different OSPF neighbors and on some you may want the router to be DR/BDR, on others not so i guess it makes sense.
Jon
Tharak Abraham
Level 3
Level 3
Kirk,
Why do you have a requirement like that ?
Remember that its the "interfaces" participating in OSPF and not the router.
So i think that explains.
HTH,
Tharak
