ospf problem? help
wilsonyong
problem:
1、show ip ospf data //have a 198.10.0.0
2、show ip route //have not a 198.10.0.0
3、show ip route //other route is good.
4、198.10.0.0 is static route redistribution to ospf.
please help!!!
I totally agree with Mohammed that the route to the fowardins address needs to be learnt via OSPF.
Do a sh ip route 10.100.70.253
This route should be learnt via OSPF to have the network installed in the routing table
have a look at this link
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009405a.shtml#t3
HTH, rate if it does
Narayan
10 Replies 10
Pavel Bykov
Level 5
Level 5
If I understand correctly, you have a static route that you redistribute into OSPF.
Static routes have better administrative distance than OSPF, therefore OSPF route will not be in the routing table. However, OSPF should send that route in advertisements to the neighbors.
Totally agree with Pavlo, when redistributed into OSPF the route will be advertised in OSPF as an external E2 route (by default), while it would never enter the local routing table as an OSPF route, as static route has an AD of 1 while OSPF routes has an AD of 110.
And please note that for a static route to be entered into the routing table in the first place its next-hop must be reachable (and the outgoing interface must be up, this according to how the static route is configured).
HTH,
Mohammed Mahmoud.
router#show ip ospf data ex 198.10.0.0
OSPF Router with ID (172.1.1.1) (Process ID 100)
Type-5 AS External Link States
LS age: 711
Options: (No TOS-capability, DC)
LS Type: AS External Link
Link State ID: 198.10.0.0 (External Network Number )
Advertising Router: 10.100.255.58
LS Seq Number: 80000014
Checksum: 0x4231
Length: 36
Network Mask: /16
Metric Type: 2 (Larger than any link state path)
TOS: 0
Metric: 1
Forward Address: 10.100.70.253
External Route Tag: 1
router#show ip route 198.10.0.1
% Network not in table
network diagram please see attachment.
Please post Area 10 configuration on A4 and A3.
Is Area 10 a form of stub area?
The route to the forward address should always be learn via OSPF if not the external route will never be installed in the routing table as in your case, can you please issue a sh ip route 10.100.70.253 and feed back us.
HTH,
Mohammed Mahmoud.
minumathur
First of all check ,Is it stub area ? 2) PPlease let send the configuration of all the router.
-Minu
Narayan
router#show ip rout 10.100.70.253
Routing entry for 10.100.70.0/24
Known via "ospf 100", distance 110, metric 1
Tag 1, type extern 2, forward metric 52
Last update from 172.21.63.13 on Serial0/2, 00:00:09 ago
Routing Descriptor Blocks:
* 172.21.63.13, from 10.100.255.58, 00:00:09 ago, via Serial0/2
Route metric is 1, traffic share count is 1
router#ping 10.100.70.253
Sending 5, 100-byte ICMP Echos to 10.100.70.253, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/12/12 ms
Is Area 10 a stub area ?
In that case A3 won't advertise external routes into Area 10.
A4 have to use default route advertised by A3 to reach external networks.
Vijaybabu
