OSPF problem
netbeginner
Level 2
Level 2
Hii,
I am configuring OSPF between two cisco L3 switches 4510 & 4507 (as of now between these switches static routes are confugured). Configured properly but it is not working..checked by removing the static routes.
router ospf 1
network 10.10.10.0 255.255.255.252 0.0.0.3 area 0
network 10.10.10.4 255.255.255.248 0.0.0.7 area 0
Where i am doing mistake pls. guide me.
30 Replies 30
Harold Ritter
Sam,
These network statements are invalid. They should use the wild mask bits only (0.0.0.3 and 0.0.0.7) not the subnet mask (255.255.255.252, 255.255.255.248). By using the following wildcard bits (0.0.0.3 and 0.0.0.7) you will include interfaces in the following ranges in area 0:
10.10.10.0-10.10.10.3
10.10.10.0-10.10.10.7
As you can see the second statement covers the first one.
Is your interface between the two devices in this range?
Hii,
Sorry i have typed wrong configs by mistake. It is actually as:-
router ospf 1
network 10.10.10.4 0.0.0.7 area 0
network 10.10.10.0 0.0.0.3 area 0
network scenerio is like this -===>
Cisco 4507 Switch ---> Cisco 4510 Switch ---> Cisco Router (on which these routes are running for one connectivity, /30 for WAN & /29 for their LAN).
Pls help.
vishwancc
Level 3
Level 3
Hi Net,
Could you elaborate the problem .
Do you mean OSPF routes are not coming to the routing tables in the switches or they are not forming neighbor relationship.
Chao
Vishwa
Hii Vishwa,
Yes u r right,
neither OSPF routes coming to routing table. Not showing neighbor status.
No output after executing command "sh ip ospf neighbor".
regards
Hello Sam,
follow Leo's suggestions about debug;
you may be facing an MTU mismatch issue between the two devices.
Hope to help
Giuseppe
nishantmj
check whether the subnet mask on both side of links are the same(must for ospf) and try to ping from both ends.If this is successful...check sh log...if something is reflecting...some ospf logs....
Leo Laohoo
Try debug:
debug ip ospf adj
debug ip ospf events
debug ip ospf hello
Hello all,
OSPF neighbor is now establised between two switches. But still the two routes running for lease lines (10.XX.XX.XX pool, /30 & /28 ) is still not reachable with OSPF after removing static route.
Hello Sam,
are network ... area commands present for the IP subnets associated to the leased lines?
post a sh ip route 10.x.x.x
May I ask you what change you did to make the two switches to build an OSPF adjacency ?
This can help to make this a complete story.
Hope to help
Giuseppe
PLease to avoid any confusion here i an enclosing the scenrio where i am configuring OSPF (Between Cisco Switch"A" & Cisco Switch"B").
Dear Giuseppe :>> I have made modification in network(10.10.1.6 & 10.10.1.5) under OSPF after which neighbor established.
Switch_A(config)#
router ospf 1
network 10.10.1.6 0.0.0.0 area 0
Switch_B(config)#
router ospf 1
network 10.10.1.5 0.0.0.0 area 0
As updated in previous posts, As present there is static route configured on Switch A towards SwitchB and then towards Cisco Router. And as i want to run OSPF between Switch A & Switch B. I am facing the problem with Lease line (WAN & LAN) route reachable when removing static routes after configuring respective networks in OSPF(As shown in above logs).
Please help to fullfill as required.
Switch_A(config)#
router ospf 1
Switch_B(config)#
router ospf 1
Hello Sam,
you have two options:
a) extend OSPF on 7613 device and have network area commands on it for the wan links ip subnets and for the link C7613 - Switch B.
b) on switch B you leave the static routes but you add
router ospf 1
red static subnets
network ... area commands are effective only for connected interfaces in OSPF.
This is the reason why the solutions are or to extend the ospf domain or to have switch B to inject in OSPF the routes from its own routing table (without removing the static routes)
Hope to help
Giuseppe
Hello Giuseppe,
Option A)--> I want to run OSPF between Switch A & Switch B only. Hence not extending OSPF to Router.
Option B)--> PLease confirm the purpose of this command on Switch B==>
router ospf 1
red static subnets
Simply asking b'coz we have other Static route also on Switch B. Will this command affect them too(i.e those static route which are not advertised under OSPF)..?
Hello Sam,
option B needs to be refined using a route-map to avoid to redistribute all static routes.
access-list 33 permit 10.10.10.8 0.0.0.3
access-list 33 permit 10.101.10.12 0.0.0.3
route-map selected_routes permit 10
match ip address 33
router ospf 1
red static route-map selected_routes subnets
Adapt access-list 33 to real ip subnets of the wan links that you want to reach from SwitchA.
Hope to help
Giuseppe
