OSPF redistribution issues
Kaushik Ray
Hello All
I am having issues with OSPF with VRF and would be grateful to have some insight as to where I am going wrong.
This is setup I have created
CE1 ---- PE ---- CE2
The configurations are as follows:
CE1
interface Loopback0
ip address 1.1.1.2 255.255.255.255
interface Loopback10
ip address 172.16.0.1 255.0.0.0
interface Loopback11
ip address 10.10.10.1 255.255.0.0
interface FastEthernet0/1
ip address 129.87.128.18 255.255.255.252
duplex auto
speed auto
router ospf 111
router-id 1.1.1.2
log-adjacency-changes
redistribute connected
redistribute static
network 129.87.128.16 0.0.0.3 area 0
default-information originate
PE
interface Loopback0
ip vrf forwarding client
ip address 1.1.1.1 255.255.255.255
interface Loopback1
ip address 2.2.2.2 255.255.255.255
interface FastEthernet0/0
ip address 172.26.2.173 255.255.255.248
duplex auto
speed auto
ip address 129.87.128.17 255.255.255.252
duplex auto
speed auto
router ospf 111 vrf client
router-id 1.1.1.1
redistribute static
redistribute ospf 111 vrf client subnets
network 10.10.0.0 0.0.255.255 area 0
network 10.130.0.0 0.0.255.255 area 0
network 172.26.2.168 0.0.0.7 area 0
network 192.168.1.0 0.0.0.255 area 0
router ospf 10 vrf client
router-id 2.2.2.2
redistribute static
redistribute ospf 10 vrf client subnets
network 172.0.0.0 0.255.255.255 area 0
CE2
interface Loopback1
ip address 2.2.2.1 255.255.255.255
ip address 10.130.4.1 255.255.0.0
ip address 172.26.2.170 255.255.255.248
duplex auto
speed auto
router ospf 10
router-id 2.2.2.1
redistribute static
On the PE the OSPF neigbours seems to be established but I cannot ping CE1 to CE2
sh ip ospf neighbor
Neighbor ID     Pri   State           Dead Time   Address         Interface
2.2.2.1           1   FULL/DR         00:00:31    172.26.2.170    FastEthernet0/0
1.1.1.2           1   FULL/DR         00:00:31    129.87.128.18   FastEthernet0/1
Now I am only able to see one of the loopbacks on the other end but not the other one.
on CE2
O E2  172.0.0.0/8 [110/20] via 172.26.2.173, 00:16:57, FastEthernet0/0
on CE1
O E2 192.168.1.0/24 [110/20] via 129.87.128.17, 00:18:08, FastEthernet0/1
I would be grateful if I can get some advice as to where I am going wrong.
Many Thanks in advance.
Hi Kaushik,
Just add "subnets" as follow "redistribute connected subnets" and it should solve your issue.
Harold Ritter
Hi Kaushik,
There are two different things here.  First, the reason you are not seeing all of the loopback addresses being advertized is that you do not use the "subnets" on the "redistribute connected" statement.
Concerning the ping not working, which source and destination addresses do you use?
Thanks Harold for your reply.
So i should mentioned both the subnets at each end on the redistribute connected?
Regarding the pings I was trying to ping loop back to loopback
ping 2.2.2.2 so lo1
Sending 5, 100-byte ICMP Echos to 2.2.2.2, timeout is 2 seconds:
Packet sent with a source address of 2.2.2.1
Success rate is 0 percent (0/5)
Hi Kaushik,
Thanks a lot Harold!
