2951 Router does not recognise VWIC2-2MFT-G703 Card
sly007
                  I have a Cisco 2951 Router with image  "c2951-universalk9-mz.SPA.150-1.M3.bin". Surprisingly, it does not recognise nor does it accept VWIC2-2MFT-G703 Cards. I have also tried it with HWIC cards but the same problem.
In the process of troubleshooting, I have upgraded the image to the level of its peers who acknowledge and accept the same cards, but success was not recorded.
What can possibly be wrong with the card or the router, and how can it be possibly fixed?
Kindly assist.
Thank you.
8 Replies 8
Richard Burts
According to this page the module should work in your 2951
https://www.cisco.com/en/US/prod/collateral/routers/ps10538/aag_c07_563807.pdf
Have you tried this module in another router to check on the possibility that there is a fault in the module?
There is a note on that page that operation may be dependent on what other modules are installed on the router. Perhaps it might help if you post the output of show version and the output of show inventory.
Rick
Rick
Thank you Richard,
I have tried the modules on similar routers (called 2951-B), and it works fine there. But has not worked on this particular one (2951-A), even after the image has been upgraded to the version of 2951-B.
Here is the output of show inventory.
NAME: "CISCO2951/K9 chassis", DESCR: "CISCO2951/K9 chassis"
PID: CISCO2951/K9      , VID: V03 , SN: FGL153310WQ
NAME: "SM-ES2-24-P: EtherSwitch SM L2 + PoE + 23 10/100 + 1 10/100/1000 on Slot 1", DESCR: "SM-ES2-24-P: EtherSwitch SM L2 + PoE + 23 10/100 + 1 10/100/1000"
PID: SM-ES2-24-P       , VID: V01 , SN: FOC14155CQS
NAME: "C2921/C2951 AC Power Supply", DESCR: "C2921/C2951 AC Power Supply"
PID: PWR-2921-51-AC    , VID: V02 , SN: QCS1529H0Y3.
And here is the output of the show version.
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.0(1)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sun 18-Jul-10 03:51 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
Kumasi_Msc uptime is 5 days, 7 hours, 24 minutes
System restarted at 09:39:19 UTC Wed Nov 20 2013
System image file is "flash:c2951-universalk9-mz.SPA.150-1.M3.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2951/K9 (revision 1.1) with 1003520K/45056K bytes of memory.
Processor board ID FGL153310WQ
4 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
999936K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2951/K9          FGL153310WQ
Technology Package License Information for Module:'c2951'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      securityk9    Permanent     securityk9
uc            None          None          None
data          None          None          None
Configuration register is 0x2102.
If you do not mind, i could show you the outputs of show inventory and show version of the other router (2951-B) as well.
I think it would be helpful to see the outputs from the other router.
Rick
Rick
Please here is the output of the show version,
Spintex_Msc uptime is 4 days, 23 hours, 35 minutes
System restarted at 18:04:37 PCTime Wed Nov 20 2013
System image file is "flash0:c2951-universalk9-mz.SPA.150-1.M3.bin"
export@cisco.com.
Cisco CISCO2951/K9 (revision 1.0) with 479232K/45056K bytes of memory.
Processor board ID FHK1433F0YG
3 Gigabit Ethernet interfaces
8 Serial interfaces
8 Channelized E1/PRI ports
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2951/K9          FHK1433F0YG
security      None          None          None
uc            None          None          None
data          None          None          None
Configuration register is 0x2102,
And here is the output of the show inventory,
PID: CISCO2951/K9      , VID: V01 , SN: FHK1433F0YG
NAME: "2 port channelized and PRI T1/E1 HWIC on Slot 0 SubSlot 0", DESCR: "2 port channelized and PRI T1/E1 HWIC"
PID: HWIC-2CE1T1-PRI   , VID: V01 , SN: FOC14182EWJ
NAME: "2 port channelized and PRI T1/E1 HWIC on Slot 0 SubSlot 1", DESCR: "2 port channelized and PRI T1/E1 HWIC"
PID: HWIC-2CE1T1-PRI   , VID: V01 , SN: FOC14182EWL
NAME: "2 port channelized and PRI T1/E1 HWIC on Slot 0 SubSlot 2", DESCR: "2 port channelized and PRI T1/E1 HWIC"
PID: HWIC-2CE1T1-PRI   , VID: V01 , SN: FOC14182EX7
NAME: "2 port channelized and PRI T1/E1 HWIC on Slot 0 SubSlot 3", DESCR: "2 port channelized and PRI T1/E1 HWIC"
PID: HWIC-2CE1T1-PRI   , VID: V01 , SN: FOC14182EYT
PID: PWR-2921-51-AC    , VID: V01 , SN: QCS1426H13H
I must say i appreciate your efforts and assistance.
Thank you.
Thanks for the additional information. I notice that the first rotuer has this Service Module SM-ES2-24-P: EtherSwitch  while the second router does not. I would suggest that you remove the Service Module and then try the VWIC again.
Rick
Rick
Oh really?
I have not done that before, and never really considered that option.
In any case, I would do that like tomorrow evening because the router is currently deployed in some location far from where i am.
I need to get a good hand to remove the ES2-24-P Etherswitch, and test with it.
Whatever the case, i would let you know.
Could you do me the favour of sharing your email address with me?
Thanks so much.
I can not say with any certainty that the Etherswitch is the problem. But it is the main difference that I see between the router that does accept the VWIC and the router that does not.
I recognize the difficulty in testing when the router is in a remote location. Please do the testing and let us know the results. My Email address is part of my profile in the community and you should be able to find it there.
Rick
Rick
I have been able to check further by tentatively removing the etherswitch before inserting the VWIC card. Unfortunately, no success is recorded.
Below are the output results of show diag, and show inventory commands.
Slot 0:
        C2951 Mother board 3GE, integrated VPN and 4W Port adapter, 3 ports
        Port adapter is analyzed
        Port adapter insertion time 00:01:57 ago
        Hardware Crypto Engine Details:
        The CHIP id is 0x0
        The SEC revision no is 0x1
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC15283VTB
        Hardware Revision        : 1.1
        Part Number              : 73-11836-06
        Top Assy. Part Number    : 800-30793-03
        Board Revision           : E0
        Deviation Number         : 111847
        Fab Version              : 03
        Product (FRU) Number     : CISCO2951/K9
        Version Identifier       : V03
        CLEI Code                : CMMBM00ARA
        Processor type           : C8
        Chassis Serial Number    : FGL153310WQ
        Chassis MAC Address      : 7081.0577.1c40
        MAC Address block size   : 96
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 35 32 38 33 56 54 42 40
          0x10: 06 15 41 01 01 82 49 2E 3C 06 C0 46 03 20 00 78
          0x20: 49 03 42 45 30 88 00 01 B4 E7 02 03 CB 8C 43 49
          0x30: 53 43 4F 32 39 35 31 2F 4B 39 89 56 30 33 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 42 4D 30 30 41 52
          0x50: 41 09 C8 C2 8B 46 47 4C 31 35 33 33 31 30 57 51
          0x60: C3 06 70 81 05 77 1C 40 43 00 60 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 03 40 01 63 FF FF FF FF FF
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        Internal power Supply information
        Top Assy. Part Number    : 341-0226-02
        Deviation Number         : 0
        PCB Serial Number        : QCS1529H0Y3
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Version Identifier       : V02
        Product (FRU) Number     : PWR-2921-51-AC
        CLEI Code                : 0000000000
        Board Revision           : A0
          0x00: 04 FF 40 05 E2 DF 45 01 55 00 E2 02 88 00 00 00
          0x10: 00 C1 8B 51 43 53 31 35 32 39 48 30 59 33 03 00
          0x20: 81 00 00 00 00 04 00 89 56 30 32 20 CB 8E 50 57
          0x30: 52 2D 32 39 32 31 2D 35 31 2D 41 43 C6 8A 30 30
          0x40: 30 30 30 30 30 30 30 30 F3 00 59 41 01 22 42 00
          0x50: 05 F8 00 50 01 F4 14 41 02 EE 16 F0 03 E8 18 C9
          0x60: 04 E2 1A 76 05 DC 1B 91 06 D6 1C 78 07 D0 1D 10
          0x70: 08 CA 1D 9E 09 C4 1E 6D 0A BE 1E A8 0B B8 1F 5E
          0x80: 0D AC 20 FB 0F A0 21 18 11 94 21 64 13 88 21 71
          0x90: 17 70 21 9F 1B 58 21 96 1F 40 21 6D 23 28 21 62
          0xA0: 27 10 21 5A 42 41 30 FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        Unknown WAN daughter card
        Unknown EEPROM ver 255
        EEPROM format version 255
          0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 1:
And show inventory,
