02-05-2014 04:44 AM - edited 03-04-2019 10:15 PM
I cannot receive any OSPF route from Nexus 7010 to ASR1004 even they are both OSPF neighbour. I have attached the config for both, Please can you have a look and advise.Both Nexus and ASR part of Area2.
NEXUS 7010
router ospf CORE
vrf 1
router-id 172.31.254.14
rfc1583compatibility
interface loopback1
ip router ospf CORE area 0.0.0.1
interface Ethernet1/1.134
interface Ethernet1/2.135
interface Ethernet1/3.136
interface Ethernet1/4.137
interface Ethernet1/5.138
interface Ethernet1/7.140
ip router ospf CORE area 0.0.0.2
interface loopback1
description OSPF ISP_2
ip address 172.31.254.14/32
NK7_MUR2-ISP_2# sh ip ospf neighbors vrf 1
OSPF Process ID CORE VRF 1
Total number of neighbors: 6
Neighbor ID Pri State Up Time Address Interface
172.31.254.5 1 FULL/BDR 00:33:58 10.36.0.118 Eth1/1.134
172.31.254.3 1 FULL/DR 00:33:56 10.36.0.122 Eth1/2.135
172.31.254.6 1 FULL/DR 00:34:01 10.36.0.126 Eth1/3.136
172.31.254.4 1 FULL/DR 00:33:54 10.36.0.130 Eth1/4.137
172.31.254.13 1 FULL/DR 00:34:00 10.36.0.133 Eth1/5.138
172.31.254.16 1 FULL/BDR 00:34:01 10.36.0.142 Eth1/7.140
ASR 1004
router ospf 2
router-id 172.31.254.16
network 10.36.0.140 0.0.0.3 area 2
network 172.31.254.16 0.0.0.0 area 2
interface Loopback1
ip address 10.31.254.16 255.255.255.255
interface TenGigabitEthernet0/0/0.140
description Conexion VDC ISP2 1/7.140
encapsulation dot1Q 140
ip address 10.36.0.142 255.255.255.252
ASR_2#sh ip ospf neighbor
Neighbor ID Pri State Dead Time Address Interface
172.31.254.14 1 FULL/DR 00:00:38 10.36.0.141 TenGigabitEthernet0/0/0.140
ASR_2#sh ip route ospf
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override
Gateway of last resort is not set
02-05-2014 09:18 AM
bienvenido a CSC ;-)
Ethernet1/7.140 seems to be the only link in Area 2 on the Nexus.
Does it have any active interfaces in the Backbone Area too?
Otherwise it will not act as an ABR between Area 1 and 2; so perhaps a Virtual Link will be needed to connect the Area 2 link to the backbone if it has to be Area 2 for this connection.
What does 'show ip ospf database' show on the ASR?
Rolf
02-06-2014 01:45 AM
I guess it would not have to create the virtual link because there physical connection between the Nexus and backboone
The nexus has multiple interfaces in area 1:
interface loopback1
ASR_2#sh ip ospf database
OSPF Router with ID (172.31.254.16) (Process ID 2)
Router Link States (Area 2)
Link ID ADV Router Age Seq# Checksum Link count
172.31.254.14 172.31.254.14 1777 0x80000072 0x00D9DB 1
172.31.254.16 172.31.254.16 2015 0x80000027 0x004698 1
Net Link States (Area 2)
10.36.0.141 172.31.254.14 1777 0x8000002B 0x00F0F9
02-06-2014 04:24 AM
The problem is that you have two non-backbone Areas (1 and 2) but no interface in Area 0, so the Nexus is not an Area Border Router. You can check that with 'show ip ospf border-router' on the ASR.
As you can see, the Link State Database shows only the single link in Area 2 (2 Router-LSAs and the corresponing Network-LSA), nothing more (originated from other Areas).
If the new link has to be in Area 2, you will have to connect it somehow to Area 0; this is an OSPF requirement.
Useful Link: OSPF Design Guide
Rolf
02-06-2014 08:19 AM
Hi Dimitri,
The issue has been solved.
We have configured the virtual link between routers and everything works fine.
Thank you very much.
