eigrp between asa and router
pamirian76
                   hi,
I have this 5520 and a router.
the asa is a vpn endpoit so let's assume 10 vpns terminate there so the asa has 10 different static routes due to the vpn.
I want to advertise these 10 routes into my core router instead of putting manual static entries in my core.
so asa has 10 x 10.50.0.0/24 subnets so let's say 10.50.0.0, 10.50.1.0, 10.50.2.0 and so on.
this is my config in the asa,
access-list EIGRP-DISTRIBUTE-LIST-IN standard deny any
access-list EIGRP-DISTRIBUTE-LIST-OUT standard permit 10.50.0.0 255.255.0.0
access-list EIGRP-DISTRIBUTE-LIST-OUT standard deny any
router eigrp 77
no auto-summary
distribute-list EIGRP-DISTRIBUTE-LIST-OUT out interface inside
distribute-list EIGRP-DISTRIBUTE-LIST-IN in interface inside
network 10.50.0.0 255.255.0.0
network 10.100.100. 255.255.255.0
passive-interface default
redistribute static
so basically I want to send the spoke vpn subnets into my core router. I want no routes from the core.
so when I do on the core, show ip route eigrp 77 I only see 1 route to 10.50.0.0/16 but yet I say to the asa not to summeraize.
this is my config in my core,
access-list 77 deny   any
router eigrp 77
distribute-list 77 out GigabitEthernet0/0/1
network 10.0.0.0
no passive-interface GigabitEthernet0/0/1
thanks for any help.
Jon Marshall
You are only allowing that specific network to be advertised out to the core with your distribute list.
The acl will do a specific match on the prefix and the mask used. If you want to advertise just the subnets and not the summary address then you would need to modify your acl and have one entry per subnet and not include the summary address as an entry.
Jon
I don't know...
I ran a test on 9.x version of ASA with a 1811 router
did this setup on the asa.
interface GigabitEthernet0/2
no nameif
no security-level
no ip address
interface GigabitEthernet0/2.1
vlan 11
nameif DMZ1
security-level 0
ip address 10.64.0.1 255.255.255.224
interface GigabitEthernet0/2.2
vlan 12
nameif DMZ2
security-level 0
ip address 10.64.0.33 255.255.255.224
interface GigabitEthernet0/2.3
vlan 13
nameif DMZ3
security-level 0
ip address 10.64.0.65 255.255.255.224
interface GigabitEthernet0/2.4
vlan 14
nameif DMZ4
security-level 0
ip address 10.64.0.97 255.255.255.224
interface GigabitEthernet0/2.5
vlan 15
nameif DMZ5
security-level 0
ip address 10.64.0.129 255.255.255.224
then I ran eigrp between the asa and router.
here is the setup on the asa,
router eigrp 77
no auto-summary
network 10.0.0.0 255.0.0.0
no passive-interface inside
redistribute static
access-list EIGRP-DISTRIBUTE-LIST-IN standard deny any4
access-list EIGRP-DISTRIBUTE-LIST-OUT standard permit 10.64.0.0 255.255.0.0
access-list EIGRP-DISTRIBUTE-LIST-OUT standard permit 10.65.0.0 255.255.0.0
access-list EIGRP-DISTRIBUTE-LIST-OUT standard deny any4
this worked just fine, on the cisco router when I do a show route I see all the 10.64.x.x networks and not just 10.64.0.0/16
(wonder if it's something with the ASA version... on this one I run 9.x on the other one I run 8.2).
Maybe i'm wrong then but usually with an acl it is a specific match ie. if you wanted to include the subnets as well you would use a prefix list.
I noticed in your original configuration you had not added the "no passive-interface inside" command but i assumed that was just a typo as the core switch was getting the summary route.
Jon
