OSPF route manipulation
tlxbx
Attached topology. All routers interfaces are part of the same /24 & area 0.
1.1.1.1/32 is adv. from both R1 & R4. Is there a way I can influence R5 to prefer R1 over R4?
42 Replies 42
Hi @tlxbx ,
You are absolutely right. The revised access-list is the proper way to go.
Perhaps:
route-map test deny 10
match ip address prefix-list prefix1
match ip next-hop prefix-list nh1
route-map test permit 20
!or
route-map test permit 10
set metric 32000
The latter possibly supporting the "auto" fail-over @Harold Ritter suggested as a good thing (which often it is).
Tried below & nothing changed.
ip prefix-list nh1 seq 5 permit 192.168.0.1/32
ip prefix-list prefix1 seq 5 permit 1.1.1.1/32
set metric 32000
router ospf 1
log-adjacency-changes
network 0.0.0.0 255.255.255.255 area 0
distribute-list route-map test in
R5#sh ip route os
1.0.0.0/32 is subnetted, 1 subnets
O 1.1.1.1 [110/2] via 192.168.0.4, 00:00:01, FastEthernet0/0
                 [110/2] via 192.168.0.1, 00:00:01, FastEthernet0/0
Did you try first alternative?
PS:
I.e.:
Hi @Joseph W. Doherty ,
Option 2 would have been a good idea, but the "distribute-list with route-map" feature doesn't allow to change anything on the route. Only the match statement will be taken in consideration. The set statement will be ignored.
BTW, found this "working [?] example" of using a "set" with an OSPF distribute-lise: https://docs.ruckuswireless.com/fastiron/08.0.60/fastiron-08060-l3guide/GUID-EB1339A2-5DCB-41D0-A215-F3A9D69174D9.html
It definitely looks like IOS, but it is not. FastIron is an NOS from Ruckus, which is a competitor.
Harold Ritter
I completely agree @Joseph W. Doherty . Sometimes the solution might be cumbersome than the problem itself.
Thank you both for your input. I'd still like to complete it at least in a lab environment. If nothing else it will solidify my  OSPF understanding
we can play with cost in two case
P2P
P2M
here we have broadcast, so only we change the network type to P2M to solve the problem
then
neighbor x.x.x.x cost <value>
this make R3 prefer either R1 or R2 for prefix Lo 1.1.1.1
Thank you. Can you do a lab with distribute-list as it didn't work for me?
It would look something like the following:
ip prefix-list nh1 seq 5 permit <nexthop to R1>
router ospf xxx
Harold Ritter
Sr Technical Leader
I am out now, but from my experience distrubte-list not work at all for this case , as @Harold Ritter mention before.
Hi @tlxbx ,
Have you been able to test the following configuration, which might be compatible with the IOS version you run.
access-list 199 permit ip host 192.168.0.1 host 1.1.1.1
router ospf 1
distribute-list 199 in
