Static Routing
hs08
If we make dual static routing with same destination and same cost, will the traffic load balance to both gateway?
return traffic path will depend how your routes are learned on remote side. There is no guarantee that return traffic will follow the same path, unless you have set your routing explicitly to make that happen.
-hope this helps-
ammahend
Yes it will
load-share
per session using source-destination IP.
you can test it easily, ping 2 different destinations and see how its routing.
you can change
load-balancing
to
 Per-Packet
although you will have some performance issues
ip load-sharing per-packet
-hope this helps-
Hi @ammahend
Noted, when there are traffic come from external then go to gateway 1 and to the endpoint, will return path from endpoint using same path or there are possibility the endpoint will reply to another gateway?
-hope this helps-
