OSPF route-map not working
davegibelli
I have the following ospf configuration:
router ospf 1
network 172.16.11.0 0.0.0.7 area 0
distribute-list route-map TEST in
access-list 1 permit 172.16.11.1
access-list 2 permit 172.16.11.2
route-map TEST permit 10
match ip next-hop 1
set metric +20
route-map TEST permit 20
match ip next-hop 2
set metric +10
However, the match statement works as expected but the set metric +10 does nothing!
Why can I not adjust received metrics?
dclark
The distribute-list command is used to prevent Open Shortest Path First (OSPF) routes from being added to the routing table. It can't really used to adjust metrics.
Giuseppe Larosa
Hello Dave,
OSPF is a link state protocol the metric is computed building a SPF tree rooted at the local node and adding link costs on the path and the cost parameters in the LSA data structure that describes the route.
The kind of action you are trying is compatible with a distance vector protocol behavior like RIP.
Hope to help
Giuseppe
