OSPF Router ID
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
04-12-2007 06:18 PM - edited 03-03-2019 04:31 PM
hi there. what the consequences if the router id is changed on the live production network? will be lsa sent to all areas at that moment? tx ;)
- Labels:
Routing Protocols
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-12-2007 11:23 PM
If a router's OSPF Router ID is changed, the
router's OSPF software should be restarted before the new Router ID takes effect.
Before restarting in order to change its Router ID, the router should flush its self-originated LSAs from the routing domain or they will persist for up to MaxAge minutes.
HTH, rate if it does
Narayan
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-12-2007 11:40 PM
Router id play important role for selection in DR/BDR if it is broadcast envirement, Depending on your enviroment , it will play role.
-Minu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-13-2007 03:21 AM
Virtual-links also refer to the Router ID.
If you are to change any router ID remember to change also the virtual-link config.
