OSPF routes E2 and OSPF topology database
Hello community,
I have a question that has been puzzling me for a while and I was hoping to find some answers.
In our environment we are running OSPF. On the network devices pointing towards the internet we have "default-information originate", so that all routers know how to reach the internet.
Running the command "sh ip ospf database external 0.0.0.0" on one of our backbone routers we get:
            OSPF Router with ID (x.x.x.x) (Process ID 1)
                Type-5 AS External Link States
  Routing Bit Set on this LSA
  LS age: 653
  Options: (No TOS-capability, No DC)
  LS Type: AS External Link
  Link State ID: 0.0.0.0 (External Network Number )
  Advertising Router: 1.1.1.1
  LS Seq Number: 80000A01
  Checksum: 0x3AB2
  Length: 36
  Network Mask: /0
        Metric Type: 1 (Comparable directly to link state metric)
        TOS: 0
        Metric: 1
        Forward Address: 0.0.0.0
        External Route Tag: 0
  LS age: 631
  Advertising Router: 1.1.1.2
  Checksum: 0x34B7
  Length: 36
  Network Mask: /0
        TOS: 0
        Metric: 1
  LS age: 888
  Advertising Router: 2.2.2.1
  LS Seq Number: 8000AFDC
  Checksum: 0x7462
  Length: 36
  Network Mask: /0
        Metric Type: 2 (Larger than any link state path)
        TOS: 0
        Metric: 1
  LS age: 927
  Advertising Router: 2.2.2.3
  LS Seq Number: 80000EE2
  Checksum: 0x472A
  Length: 36
  Network Mask: /0
        TOS: 0
        Metric: 1
  LS age: 814
  Options: (No TOS-capability, DC)
  Advertising Router: 3.3.3.1
  LS Seq Number: 80000234
  Checksum: 0xBBA5
  Length: 36
  Network Mask: /0
        TOS: 0
        Metric: 1
        External Route Tag: 3489667727
As you can see routers 1.1.1.1 and 1.1.1.2 advertise 0.0.0.0 as E1 type links. Routers 2.2.2.1, 2.2.2.2 and 3.3.3.1 advertise 0.0.0.0 as E2 type links. In normal operation 0.0.0.0 shows up in the routing table either via 1.1.1.1 or 1.1.1.2. My question involves the failure of 1.1.1.1 and 1.1.1.2. In practice we have seen that if both 1.1.1.1 and 1.1.1.2 fail, then 0.0.0.0 is advertised via 2.2.2.1 or 2.2.2.2 (which is what we want!). But why are these routes preferred in contrast to 3.3.3.1, since all have the same metric-type E2 ????
We do not with 0.0.0.0 to be learnt via 3.3.3.1, so just to be on the safe side, I will change the metric-type of 2.2.2.1 and 2.2.2.2 to E1 with a metric of 20, so that the network prefers 1.1.1.x first and in case of a double failure,  2.2.2.x will advertise the default route.
I would be grateful if someone could shed some light!
Hi Katerina,
Even if all routes from 2.2.2.1, 2.2.2.3, and 3.3.3.1 are External Type-2 routes with metric 1, the forward metric could be different for 3.3.3.1. Note that: OSPF takes into consideration the forward metric for E2 routes if they have equal metric. In simple terms, the forward metric is the metric value to reach to the ASBR.
You can get detailed explanation in the following link:-  https://blog.ine.com/2011/04/04/understanding-ospf-external-route-path-selection
HTH,
Meheretab
HTH,
Meheretab
Hi Katerina,
HTH,
Meheretab
HTH,
Meheretab
This knowledge was tucked away somewhere in the back of my brain! Thanks for helping bring it forth!
