OSPF setup help
avilt
Level 3
Level 3
I have my setup as shown below.
Area0<----Router-A---->Area0<----Router-B---->Area1
ROUTERB:
interface GigabitEthernet0/0
ip address 10.10.126.9 255.255.255.192
ip ospf message-digest-key 1 md5 XXXXYYYY
interface GigabitEthernet0/1
ip address 10.10.88.142 255.255.255.192
ip ospf message-digest-key 100 md5 7 XXXXYYYY
ip ospf priority 254
router ospf 65182
log-adjacency-changes
area 0 authentication message-digest
area 1 authentication message-digest
network 10.10.88.142 0.0.0.0 area 1
network 10.10.126.0 0.0.0.63 area 0
Do I also need to put the following command on router-B?
network 10.10.126.0 0.0.0.63 area 1
2 Accepted Solutions
Mahesh Gohil
Level 7
Level 7
Hi Avilt,
if you write this command the below statement
will be over written as
and your ospf config will look like
router ospf 65182
and the impact is you will not find ospf adjacency between RouterA and Router B.
Mahesh
Hello ,
No , the 10.10.126. segment is part of Area 0,
This route you will see it in Area 1 , if you have more then Router B in this area , as intre-area route (O IA).
Dan
9 Replies 9
Jerry Ye
Is 10.10.126.0 0.0.0.63 in area 1 or area 0? You need to configure which interface is going to participate in OSPF in Router A. You need to put the OSPF authentication in Router A also.
HTH,
jerry
Mahesh Gohil
Level 7
Level 7
Hi Avilt,
router ospf 65182
Mahesh
Can you share the configuration for both the routers ?
ROUTERA:
ip address 10.10.126.54 255.255.255.192
ip address 10.10.88.199 255.255.255.240
ip ospf message-digest-key 1 md5 7 XXXXYYYY
router ospf 65182
network 10.10.88.199 0.0.0.0 area 0
ROUTERB:
router ospf 65182
On router-B, in order to advertise the route to 10.10.126.0 in area-1, do I also need to put the following command on router-B?
Hello ,
Dan
I am bit confused about the usage of network command in OSPF.
For example in the following config, if I do not add the command "network 10.10.126.9 0.0.0.0 area 0" is the router going to advertise the route to network 10.10.126.0 in area0 on the interface GigabitEthernet0/1?
TESTROUTER:
router ospf 65182
network 10.10.88.142 0.0.0.0 area 0
Hi Avilt,
In case of ospf if you want to enable ospf on interface then you will have to put the IP  of that interface
via. network command in ospf.
Network command serve two purpose.
1- Help in estlablishing neighbor relationship with connected interface device
2- and advt. that network in ospf
For your query. You already have ospf route for network 10.10.126.0 on router B then you need not to put it in network command to advt. on your interface
GigabitEthernet0/1. You will see that network advt. on other routers as Net summary link.
Please issue "sh ip ospf database" to verify the same on router connected to GigabitEthernet0/1
Please feel free to write if you have any more query
Mahesh
Thank You Mahesh.
Just to clarify further regarding point 2
Is this command goint to advertise every active route even though the network command is not defined for every network ?
Hi Avilt,
This will advt. the route covered under this subnet. I mean if you put 10.10.10.0/16 then it will advt. all active route
belongs to that subnet
Hope this is clear to you
mahesh
