WCCPv2 and process switching
hank
We have a 7206VXR NPE-G1 running 12.3(4r)T3.
WCCP shows the following:
Global WCCP information:
    Router information:
        Router Identifier:                   x.x.220.57
        Protocol Version:                    2.0
    Service Identifier: 80
        Number of Service Group Clients:     1
        Number of Service Group Routers:     1
        Total Packets s/w Redirected:        1249345
          Process:                           1249345
          CEF:                               0
        Service mode:                        Open
        Service Access-list:                 -none-
        Total Packets Dropped Closed:        0
        Redirect Access-list:                1
        Total Packets Denied Redirect:       913841423
        Total Packets Unassigned:            0
        Group Access-list:                   -none-
        Total Messages Denied to Group:      0
        Total Authentication failures:       0
        Total Bypassed Packets Received:     0
Everything is process switched and not CEF switched.  The config shows the following:
ip wccp check services all
ip wccp 80 redirect-list 1
and on the relevent interface:
interface GigabitEthernet0/1
ip wccp 80 redirect in
ip flow ingress
ip pim sparse-mode
no ip route-cache cef
no ip mroute-cache
duplex auto
speed 1000
media-type rj45
no negotiation auto
What needs to be fixed to make it all CEF switched and bring down the CPU from 75%?
Thanks!
Giuseppe Larosa
Hello Hank,
first of all, you can try by re-enabling CEF on the inbound interface:
interface gi0/1
ip route-cache cef
because it is currently disabled.
However, this could break WCCP service so do it during a maintanance window. it has been disabled by someone with a purpose ( or not ?)
So I would also recommend to upgrade your IOS to a 12.4T image because it is rather old
see
http://www.cisco.com/en/US/docs/ios/ipapp/configuration/guide/ipapp_wccp_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1090519
12.2(33)SRE is recommended for VRF aware WCCP
Hope to help
Giuseppe
