OSPF Summarisation of Redistributed Static Routes
ryan-barton
Hi I have the following topology in GNS3:
Currently only concerned with R1/2/3 which are all in area 0, I have created static routes on R1 as below:
ip route 77.1.0.0 255.255.255.0 66.1.1.2
ip route 77.1.1.0 255.255.255.0 66.1.1.2
ip route 77.1.2.0 255.255.255.0 66.1.1.2
ip route 77.1.3.0 255.255.255.0 66.1.1.2
I have redistributed these into OSPF and have the below config:
router ospf 1
router-id 1.1.1.1
auto-cost reference-bandwidth 100000
area 123 nssa no-summary
summary-address 77.1.0.0 255.255.252.0
redistribute static metric-type 1 subnets
passive-interface default
no passive-interface GigabitEthernet1/0
no passive-interface Loopback0
I want to summarise the 77.1.0.0, 71.1.2.0 and 71.1.3.0 into the summary address summary-address 77.1.0.0 255.255.252.0 but still want to have a specific route to the 71.1.1.0 network, how can i do this?
18 Replies 18
ryan-barton
Sorry I meant R1/2/3 are all in area 123 not area 0
You need two router to add NSSA area to topology then redistrubte static to ASBR of NSSA area then summary these prefix.
MHM
Thanks MHM,
already have NSSA area configured on R3 aswell as below:
router ospf 1
router-id 3.3.3.3
no passive-interface GigabitEthernet2/0
no passive-interface GigabitEthernet3/0
I can also see the summary route on R3:
O N1 77.1.0.0/22 [110/121] via 192.168.13.1, 00:02:32, GigabitEthernet1/0
Just unsure how to also ensure the more specific 71.1.1.0 route is also shown
Got it'
I will check how we can get summary and only one prefix
MHM
sorry I can not find solution
you can use
summary-add <> not-adv
to prevent ABR of NSSA to translate some prefix but
make summary and prevent translate that not work
MHM
Hello @MHM Cisco World
Remove those existing summary's and add the following:
summary address 1.0.0.0 255.0.0.0
summary address 1.1.0.0 255.255.0.0
Kind Regards
Paul
Friend this not work
When you summary to 1.0.0.0 255.0.0.0
All prefix within this range will not advertise i.e. 1.1.0.0 255.255.0.0 and 1.2.0.0 and so on
That why I answer him, he can not get both use summary abd prevent some prefix
MHM
Hello
This IS possible, you just need two summary's, one being more specific related to the "leaked" route, in your OP you have the summarys statements incorrect
Kind Regards
Paul
friend share lab to make it short for all
as I mention again I have three 1.1.0.0 1.2.0.0 1.3.0.0 I can make ABR not translate LSA7 into LSA5 for only 1.1.0.0 that it
I can not summary three prefix into one 1.0.0.0/8 and advertise two 1.2.0.0 and 1.3.0.0
that all
MHM
correct as it is a summary! -  however is you wish to "LEAK" a specific route from that summary from an ASBR you just need to add an additional summary which is more specific to the route you wish to advertise.
Kind Regards
Paul
and He ask how we can do this leak
I answer I couldnt found solution
if you have answer him with lab
simple lab three routers
MHM
Hello @MHM Cisco World @ryan-barton
I have not labbed this, not access to at this time anyway, but i believe I dont need to the ASBR summary's as I explained should work ...
Based on the  OP the cfg I have previously posed also should work accordingly
Kind Regards
Paul
Hello
R1 = ASBR
R3 = ABR of the ASBR
So if you make r3 a NSSA ( so NOT a  not-to-totally stubby area)  R3 should receive all the specific routes as well of all the other internal rtrs to area 123 whilst the all other areas just receive a summary
EDITED
R1 (ASBR 123)
router opsf 1
summary-address 77.1.1.0 255.255.255.0
area 123 nssa
R3 (ABR for area 123)
router ospf 1
Kind Regards
Paul
Hello Paul,
Thanks for your feedbcak, is there a reason the 2 routers cannot be totally NSSA in this scenario?
Kind Regards,
Ryan
